Paint/Body Corvette Materials, Techniques, and How To
Paint runs
Old Jul 26, 2022 | 10:39 AM
fake's Avatar
fake
Default Paint runs
Run Razor have you used one? Where did you buy it?
Old Jul 26, 2022 | 06:37 PM
dragjag's Avatar
dragjag
7th Gear
Default paint run
cover with glazing putty then sand out the run
Old Jul 27, 2022 | 08:43 AM
fake's Avatar
fake
Explain that glazing putty in detail. We talking a paint run on clear coat .
Old Jul 27, 2022 | 08:54 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
I take a razor and scrape the run flat - then wet sand and buff
Easy Peezy
Old Jul 28, 2022 | 07:44 AM
dragjag's Avatar
dragjag
7th Gear
Cover it with a light coat of polyester glazing putty sand out the run then the rest of the glazing putty without sanding through the clear around it
Old Aug 10, 2022 | 01:59 AM
c3paced's Avatar
c3paced
5th Gear
All that is needed is a razor blade, hold firm and drag the razor blade over the run. Sand the run alitle first and make sure you have a sharp blade
Old Aug 16, 2022 | 11:39 AM
fake's Avatar
fake
Is this the same on clear coat. After you sand the clear coat out then what do you do shoot new clear coat?
Old Aug 16, 2022 | 11:47 AM
HandOverFist's Avatar
HandOverFist
If done correctly you will simply wet sand/buff to bring back the original luster. This requires very fine grit. If you have sanded through the clear into the color you are done...
To Paint runs
