Painting my 59 with some old Lucite that I have. 5 coats applied with medium thinner, then wet sanded with 1000 to get it smooth again and painted with 5 more coats. First time spraying lacquer. I thought it went down dry, but nice, no orange peel or runs.
My question is how long should I wait to begin final sanding and then buffing, and should I begin with 1000, 1500 or even something else?
Thanks Joe
Damn. This is how old I am. Wait about a week to let the solvents cure out "completely". I don't understand "it went down dry"--it should have been glossy enough to see your reflection in the surface as you sprayed. I hope you're talking about sanding the clearcoat. From your description of your prep for the last 5 coats I would think 1000 grit is plenty cautious--maybe knock down the "sharpness" of the sandpaper by VERY lightly wet sanding it against itself (including the corners of the paper).
Lacquer need 7 to 10 days before buffing and 30 days before applying wax. If theres no nibs or dry overspray Id try buffing with foam pads and 3m or mequires 205 using a DA buffer first. If that doesn't work try 5000 wet using a wet orbital sander, then switch to 10000 grit wet. Lacquer inst very durable and its not hard to sand right through it.
When I mentioned it went down "dry", it did have a wet sheen very briefly before drying and turning to a satin that wasn't slick to the touch. 1.4 nozzle, 20 PSI at the gun. Gravity feed.
Wasn't really sure about intervals, and never would have guessed 30 days to wax. I colorsanded yesterday 7 days out with 1000 and1500 and want to do some compounding/buffing by the end of the week. Smooth and picked up "some" shine and depth.
