Paint/Body Corvette Materials, Techniques, and How To
67 Stinger Wrong Geometry Fix Options
Old Nov 25, 2023 | 11:46 AM
Googoo427's Avatar
Googoo427
Default 67 Stinger Wrong Geometry Fix Options
My buddy had his 67 427 repainted back in the late 90s in it's original Marina Blue with a white stinger. The car hasn't been driven much until recently following his retirement. Paint was done in base coat/clear coat. The painter guessed at the geometry of the hood stinger. The geometry is way off relative to what GM did. It bothers him immensely. I was able to obtain guidance from an NCRS member who provided me with the correct geometry. My question is this. What are the best options to address the stinger issue? Is it even possible to sand down through the clear and carefully remove all of the white stinger than reapply the correct white stinger and reclear? Or, does the entire front end need to be repainted? Keep in mind that the nose of the stinger goes into the front of the car. Not all of the stinger is isolated to the hood only. Any thoughts as to how to best address this would be appreciated.
Old Jan 15, 2024 | 11:48 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I think the best bet is to take if to an experienced painter who is expert at matching and blending. Base/clear is a good situation to begin with since he won't be dealing with modern paints and lacquer or enamel compatibility. If zero body work needs to be done, the scoop to point could be sanded to prep for paint, then spray & blend in Marina Blue over the entire hood, fender tops, and headlight panel. After this, it's just a matter of taping and shooting the white stinger and topping it all off with clear.
Old Jan 16, 2024 | 04:36 PM
Googoo427's Avatar
Googoo427
Thanks for the response. I arrived at the same conclusion.
Old Apr 4, 2024 | 07:59 PM
Gary D. Jaynes's Avatar
Gary D. Jaynes
You should keep in mind that when redoing the stripe it should not have any clear on it.
Old Apr 4, 2024 | 09:54 PM
Joe C's Avatar
Joe C
Originally Posted by Googoo427
...my question is this. What are the best options to address the stinger issue? Is it even possible to sand down through the clear and carefully remove all of the white stinger than reapply the correct white stinger and reclear? Or, does the entire front end need to be repainted? Keep in mind that the nose of the stinger goes into the front of the car. Not all of the stinger is isolated to the hood only. Any thoughts as to how to best address this would be appreciated.
no way can you sand the stinger away without damage to the base. IMO, the only option is a repaint.
To 67 Stinger Wrong Geometry Fix Options
