C5 frame clean/strip and repaint
I have a '99 FRC that I have disassembled so I can get all of the road salt and other gunk off of the frame before it can rust through. I'm looking for tips on how to get started. I have a portable media blaster that I plan on using (unless y'all tell me not to).
Any tips for repainting it would be appreciated. I'm not too concerned about it looking good, but I want to do it well enough that the frame is thoroughly protected.
When you say "disassembled," do you mean that the body is off the frame?
I took my '71s body off the frame for a complete restoration. Just surface rust on the main frame so I blasted it out in the driveway because it was already apart so why not? I sprayed Eastwood Internal Frame Coating on the insides and then brushed POR-15 on the outsides. I was happy with the results. If the rust isn't too bad, they say that POR-15 [Paint Over Rust] can be used without fully derusting but all the loose flakes should be removed.
As for repainting, I have no experience with that - it's coming up on my project after I get all the old paint off and do some body repairs...
In lieu of that I would still blast it and use Rustoleum primer and paint products. I assume after all your work it won't see any harsh weather.
Pic of 68 C10 project using Rustoleum products.
Sorry about that! I didn't even think of including a picture. I'll add it to the first post. The white gunk is mainly road salt and maybe some mold. I should have been more careful with words. Repainting isn't exactly what I meant. POR-15 will work fine. Thank you for recommending it!
I'm really bad about keeping cars away from harsh weather. I just like to drive my toys. I'm in North Carolina now, so it won't see any road salt again! It'll probably see rain if I can stop the turbos from ingesting the water.
**For some reason, I am getting an error saying to shorten my post to 600,000 characters or less. I think the site is glitching.
