Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Wheel Hop
Old Jan 26, 2005 | 07:56 PM
98vert6spd's Avatar
98vert6spd
Default Wheel Hop
HOW DO YOU GET RID OF IT ?
I havea 98 convertible with base suspension
if i dump the clutch at anything over 2k i get serious wheelhop
i am runnign GSD3s
its cold as hell here and i dont drive it in thw winter but last time i did i had magor wheel hop
i have an intake and long tubes
so im not laying down serious numbers
whats the solution?
Old Feb 10, 2005 | 02:54 AM
kardashim's Avatar
kardashim
alot of people have this problem. i had a 98 coupe for a while, but am without a vette right now, and am going to get a Z06. i remember when I got rid of my runcraps and bought the new Michelin PS2's....that made a HUGE difference. HUGE. those tires were the best street tires I ever drove on. the best. and I drove the d3's too. and right after that I lowered it, and that also helped, i rarely noticed it after that. alot of people will disagree on this probably, but I think it's a suspension issue. First, in the design of the car...the monospring concept. But as I was saying, I think to get rid of wheel hop, the best thing to do is get the fe1 suspension, or base suspension. it's soft, and absorbs the weight transfer to the rear. I'm thinking the stiffer the suspension, the more hop. better for corners and all of that stuff of course. but the torque just needs to go somewhere, just needs to be absorbed? what suspension package are you equipped with? and maybe a full tank of gas might help..the added weight. Corvettes are light and powerful. very torquey. i wonder if those who use a 19" tire still experience this? let me know if you get rid of it somehow.
Old Feb 10, 2005 | 07:52 AM
Assassin_808's Avatar
Assassin_808
from what I understand about the majority of wheel hop on the vettes is due to cold weather and or cold tires... there is somebody that can explain it alot better on here somewhere... try heating up your tires good and try it again...
Old Feb 10, 2005 | 10:02 PM
lost's Avatar
lost
Up grade your shocks and sway bar, that eliminates a lot of it.ZO6 parts work very well but they are not your only choice.
To Wheel Hop
