Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Burnout time difference?
Old Mar 26, 2005 | 06:58 PM
StoCK's Avatar
StoCK
Default Burnout time difference?
Say that two identical corvettes driven by drivers with identical skill are about to run the 1/4 mile. The only difference is one car does a burnout, while the other does not. How much of a difference will there be in their 1/4 times?
Old Mar 26, 2005 | 07:26 PM
Ranger's Avatar
Ranger
There are variables. (1) what tires (2) tranny type (3) power of the car (4) track prep.
But my Z06 (M12 tranny) with me driving on stock tires, a good burnout improves the 60' by about one tenth. On drag radials, the burnout is worth at least two tenth in the 60' and another tenth gain in holding the shifts.
Others can speak to C5s with run-flats.
Ranger
Old Mar 26, 2005 | 11:10 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
My guess is you are talking stock run flats and the difference may be less than a tenth
Old Mar 27, 2005 | 11:13 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I'd say about .1 as well...
Ron
Old Mar 28, 2005 | 02:22 PM
mdhmi's Avatar
mdhmi
Depends. If both cars dead-hooked without doing a full scale burn-out I would say nothing would be gained by doing a burn-out.
Mark
Old Apr 18, 2005 | 04:21 PM
2000BSME's Avatar
2000BSME
see my sig for mods, burnout did NOTHING for me in a 10 run trial. NOTHING. I suspect my weak link is my stock TC and 3.15's.
Old Apr 19, 2005 | 09:39 AM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Burnouts serve two primary functions. The first is to clean off the tires - dirt, grass, small pebbles, etc. The second is to raise the temperature of the tread surface to match the track conditions (+25 degrees is about ideal on ET Streets). On tires designed to drag race the increased temperature brings sticky chemicals to the top of the tread surface. On stock DOT tires cleaning the tread will probably help but raising the tread temperature is not going to get you much if anything.
Old Apr 19, 2005 | 10:22 AM
C5 CU's Avatar
C5 CU
on DR the difference was a 1.7 vs a 1.9 60ft....also made difference on getting wheel-hop or not....on stock tires I never noticed much difference on 60ft but did notice less wheel-hop after warming them up a little.
Old Apr 20, 2005 | 01:47 PM
shurite44's Avatar
shurite44
I am guessing you are talking about stock runflats. I have read many posts on the forum that heating up a runflat will not help your launch. My personal experience when I was all stock was my tires would spin on the launch if I did no burn out. If I heated up the runflats I could launch with no tire spin. It made very little difference in ET or 60 foot times but it did make a difference in consistency of my ET. I found that if I spin it was hard to predict my ET consistently so I chose to do a mild burnout each run. Part of my experience though is at the track I race it is next to impossible to drive around the burn out box. So a burn out was necessary or you had to launch with wet tires. Just my two cents.
Old Apr 28, 2005 | 07:26 PM
GTSLN97's Avatar
GTSLN97
A nice burnout on my runflats helped me out a lot. Everytime my burnout got a little bigger, my run was a little faster....
Old Apr 28, 2005 | 09:04 PM
Special K's Avatar
Special K
Ranger
He said identical cars. So the only question is what type of tire andf how much power they have.
Run flats would be a waste of time with anything over one spin for cleaning. My almost stock C5 has no traction issues with DR's. Burnouts aren't necessary. I think only high horsepower applications require a good burnout.
His question can't be answered.
Old Apr 28, 2005 | 09:14 PM
Ranger's Avatar
Ranger
Original poster is collecting data from members with a variety of set-ups. I tried to state the variables that contribute to "how much difference" the burn-out would make. For example, your rwhp but with an M6 tranny WOULD see an improvement from the burnout, which you do not with your A4. Sorry if I was not clear.
Ranger
Old Apr 28, 2005 | 10:08 PM
Special K's Avatar
Special K
Ranger
I'm sorry Ranger, but I don't get it. Maybe I need some sleep. This is what he posted: "Say that two identical corvettes driven by drivers with identical skill are about to run the 1/4 mile. The only difference is one car does a burnout, while the other does not. How much of a difference will there be in their 1/4 times?"
I read that as two identical cars. I don't see a variety of setups. I'll get some sleep and maybe I'll see it in the morning.
Old Apr 28, 2005 | 10:13 PM
shurite44's Avatar
shurite44
Bob, he is saying that this identical car could be two identical A4s, or two identical M6s, or two identical Z06s.
Old Apr 28, 2005 | 10:19 PM
Special K's Avatar
Special K
Thanks Gary. Now I understand what Ranger was saying. His question still can't be answered. We don't know what the cars are. If they're like mine, a burnout means nothing. But like Ranger said, a standard would make a difference.
Old Apr 29, 2005 | 01:38 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I can answer...........
Track rental 4/22/05
Me racing our 00' Vert within 10 minutes of my Wifes last run.
Hers............12.58@111.83 with a 1.98 60' ( no burnout for her )
Mine............12.29@111.33 with a 1.72 60' ( burnout)
Bob
More info:
http://forums.corvetteforum.com/show...21&forum_id=90
http://forums.corvetteforum.com/show...4&page=1&pp=20
To Burnout time difference?
