10 sec 2000 coupe..
Need to sell one of my C5's and here is the info on the best one:
2000 Corvette Street/Strip/Road Race!
This is the RevXtreme show car. RevXtreme the Tampa based tuner.
This is the 2000 Pewter coupe with over $24k of after-market mods that they used as the demo/show car. The car is set-up for road-race but has not been raced, only shown & some 1/4 mile runs.
Mods include:
Motor just installed w/ new alternator/starter/water pump/etc. 02/17/05 with Comp Cams .595-581 lift cam, Harland Sharp roller rockers, Comp springs & push rods, (motor is a 2003) Dynoed at 400 RWHP w/out spray (601 sprayed); Breathless Rammer & carbon fiber bridge; Brand new Spec-3 matched clutch/pressure-plate/flywheel; rebuilt and upgraded road-race transmission (steel keys, shift forks, c/f blocking rings, etc.); 3.73 gears; upgraded axles; hardened output shaft; Wolfcraft racing 6pt roll cage; RJS Racing 5 point harness; Baer Eradispeed brakes; HID headlights, ZO6 grills and brake ducts, QTP stainless "race" headers; QTP dual electric cutout stainless X-pipe; Corsa catback; front brake line lock system; BMR sway bars (front and rear); NX nitrous wet kit w/window switch, multi-stage, etc. kit; competition ready sound system with Pioneer head unit, twin 600 watt amps, Stinger power block, and Rockford Fosgate Sub; new black ZO6 Motorsport wheels; new Kumho Ecsta Supra's (275 - 35ZR 18 frnt); top of the line Viper Alarm system, with perimeter sensor, automatic windows, etc; Specter rear fascia w/lip; PIAA driving lights; New Optima Red Top battery; short shifter ( the B&M Ripper w/MOMO ****); Autometer Nitrous psi and Fuel psi gauges in pillar pods; European tail lights; and Heads Up Display (which is a factory option, not really aftermarket). I'm sure I have missed some, but you get the idea.
Chassis has 66k miles on it, most of the rest is brand new or nearly new. Interior is near excellent with a small tear in the drivers outside bolster. Would cost in excess of $60k to duplicate. This car can win a show and go out and run a 10 second 1/4 mile pass or run at Sebring!
Contact Phone Number: 727-422-0076
Thanks!
Tracy
