First off, I'm dynoing right about 400+/380+. Now my problem is that prior to getting Drag Radials I was trapping 114-115 (run craps), now after I'm trapping 111-112s. Is that normal? Here an example of my time change:
I'm just curious as to why I drop almost .4 on my 60 ft, yet my time only dropped by .3? Any suggestion? Also do those times sound close to what I should be running. Not sure if this helps, but I'm running stock 3.15s w/ a 3200 stall.
you got traction. Spinning will yeild high trap speeds.
Well can you explain why I've dropped almost .4 on my 60 ft, yet my time only dropped by .3? Also do those times sound close to what I should be running.
When I switched from OEM thin spokes to aftermarket 18 x 10.5 think spokes I lost a tenth and one to two mph, because of the increased weight of the wheels. Not sure if this helps, your times have me stumped to be honest.
They seem to be stumping quite a few people, only 9 post (half by me) and 70 views. I need some insight.
Tru_Ice, maybe you should post exactly what mods you have on the car. That may help a little. Also are your new wheels aftermarket reproduction wheels, I am assuming they are.
what I found for my car on DR was that a little spin on launch acutally help my overall 1/8th and 1/4 ET and MPH....seems if a little spin then the front end stays up and no loss of momentum during launch????
Few things that come to mind.
Exactly what Vette do you have in comparison to your buddies Z?
Non Z Vettes weight ~100 lbs more. I'm suspecting you have a non Z.
Also, Z's are geared more aggressively.
The come stock with a 3.42 (or something like that).
Also, a 6 speed manual driven properly and able to withstand the power of the motor, will yield slightly better times than an auto.
Between these three, it could easily make the .2 difference your seeing between your car and your buddies Z even with the power difference.
Actually, I don't see anything to be puzzled about.
Time of year difference maybe. Plays hard on mine. I just have a stock engine and pulled a 12.64 @ 109 w/ 1.86 ft on regular 555's. Pt2400 and 3.73's with average bolt on's. I guess around 315hp. never dynoed. I will see what drag radials do for me Saturday. I give it all she has off the line, no holding back. Stall it till it almost wants to spin and stab it on go. Usually I fry the tires past the 60ft but it's sure looks good.
I see you’re in Texas. Were all your runs made in very hot temperatures? First of all I would expect that with 405 RWHP that you’d be trapping 118+ mph. If you made the runs with the run-flats earlier in the season in cooler weather, that could account for the discrepancy. The .4 in the 60’ should have given you at least .6 in the ¼. If the air is considerably hotter it could really affect your results.
This is a complete wild guess but I notice that the DR’s you’re using are probably an inch shorter than the run-flats. I wonder if this could have anything to do with it. Were you going through the traps in 2nd or 3rd gear with the run-flats? Are you going through the traps in the same gear with the DR’s? I don’t know anything about automatics, but could a 1 inch reduction in tire height affect your shift points etc?
It would also be helpful if you could post all your splits. That way we would be able to see where your car is laying down.
My friend has a Z, I have a Coupe. The only mods on his car are a clutch upgrade, and vararam. As opposed to my
About 85+ degree weather here in WA, the runs were made a week apart from each other.
Running through in 3rd. I never really thought of that, I was thinking that it was the additional unsprung mass. I think the added weight might have caused the issues.
You don't think his times before and after tire/wheel change look strange? He is .3-.4 faster in the 60', and .2-.3 faster in the qtr mile, but his trap speed dropped by 3 mph. His only change was wheel's/DR's. If you don't see anything strange about that please post why this happened because I would be very curious and you would basically answer the question he is posting in the thread.
You don't think his times before and after tire change look strange? He is .3-.4 faster in the 60', and .2-.3 faster in the qtr mile, but his trap speed dropped by 3 mph. His only change was DR's. If you don't see anything strange about that please post why this happened because I would be very curious and you would basically answer the question he is posting in the thread.
Sorry if I was not clear. By “splits” I meant all the information from your time slips i.e. 60’, 330’ 660+Mph, 1000, 1320+mph. That way we can look at the DR runs compared to the run-flat runs and figure out at what point you’re losing time. I always like to see the 660 (1/8th mile) time and mph. Generally when there is a problem the 1/8th mile numbers will be way out of whack with the ¼ mile numbers. I would guess your 1/8th mph should be around 90mph. What is the altitude of the track where you’re running?
You might want to bring both sets of tires with you, and run both on the same night. That will remove some of the variables associated with running on different days.
Sorry I misread I see you’re in Washington, not Texas. Hope I didn't make you home sick.
