Drag tips for a A4 SC
I'm running a Procharger 6 psi, 42lb inj., ,224/224 581/581 with ported stage II heads. kooks 1 /34 borla catbacks, Level 5 trans, TCI 3500 TC, 2.42's with Nito DR's.
Have not dyno'ed yet and is running rich and tuning is the best I could do with PC Tuners. Assuming I am at 550 RWHP or so -
I ran 3 runs at 12.914,12.916 and 12.933
take in consideration that my R/T's were terrible.
1st run at 1000 RPM (idle) to WOT at the tree
2nd 300 rpm launch
3rd run 2500 launch.
at 3/4 track, I was hitting the rev limiter and had to let off WOT each run
Here are the questions:
What is the best procedure for practicing reaction times?
Is it possible that my R/T's over 1 second is part of the problem?
I have HAL adjustible shocks - whats the best setting for drags?
I did not release air from the DR's - I ran at 32 lbs. - What would be a good starting point for drags at wat bar./temps at the track?
Should I run full tank for weight at the rear?
Since I have a TCI 3500, should I allways launch at this RPM?
I did spin for 50+ feet on the second run, but tire pressure, shock settings might improve the traction?
Ok, now the part tha's killing me - I am hitting the rev limiter in the top of 3rd - what can i do to avoid this (using PC tuners)
I have adjusted the torque vs. rpm vs. gear tables but can't get it right!
Thanks to all who can offer advice...
K
Second, you need to let air out of your tires and do a smokey burnout. I had good luck with 20-22 psi in BFG drag radials. Get them wet, then spin them till you see smoke for a couple seconds. Since you're running nittos, you'll need to smoke them for a little longer if you want to hook.
As for shock settings, do a search here. IIRC, you want to stiffen up the back of the car, and loosen the front. So 2 up front 6 or 7 in the rear. If that doesn't help, go lower in the rear.
Just curious, what were your 60's and 1/8th's (et and mph)?
I don't have to time slips with me, but I believe My 60' times were 1.8-1.9 and 1/6 around 8 ish. I have a Vert with a supercharger not nitrous. Since I'm hitting the rev limiter a 3/4 pass and have to let up and mash again, I'm sure this is losing time here. I just can't believe that all 3 runs are as bad as I thought they would be - thinking I would at least be in the low 11's.
K
just my setting with my car!
