Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Installed ported T.B. WOW
Old Oct 9, 2005 | 12:51 AM
Vette#2's Avatar
Vette#2
Default Installed ported T.B. WOW
This must be what my setup needed! Bought a CNC machined T.B. from Katech & did a Coolant bypass while I was at it. The idle lope has become louder same while driving. Midrange power really pulls even more. As the computer adjusts itself I expect even more from this setup. I feel the $165. was well spent
Old Oct 11, 2005 | 10:56 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Awesome brother!!! Track this weekend yes? I will be
Dave
Old Oct 11, 2005 | 05:43 PM
C5XTASY's Avatar
C5XTASY
Great that it worked out for you. I was planning on going with a Shaner. What was it about the Katech that made you decide to go with them?
BTW, I've decided to have a Yank SS3200 installed and run it with my 3.15s. Thanks for your thoughts and advice. Another question, did you order the Yank driveplate for $159, or use your stock plate? did you experience any vibration following the torque converter installation?
Ed
Old Oct 11, 2005 | 08:41 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Originally Posted by C5XTASY
I've decided to have a Yank SS3200 installed...
Old Oct 11, 2005 | 09:42 PM
C5XTASY's Avatar
C5XTASY
Originally Posted by ToplessTexan
Et tu, Brute'?
Old Oct 12, 2005 | 01:07 AM
Vette#2's Avatar
Vette#2
Ed
Katech is about 4 miles from my home, AND they are the people who have been & are building the engines for the C5-C6 factory racing teams. Need I say more
Old Oct 12, 2005 | 07:38 AM
C5XTASY's Avatar
C5XTASY
Do you happen to have their website address? I tried www.katech.com but it didn't work. Thanks!
Ed
Old Oct 12, 2005 | 10:15 AM
Vette#2's Avatar
Vette#2
Ed
Try this , katechengines.com if you phone ask for Jason.
Old Oct 12, 2005 | 01:24 PM
C5XTASY's Avatar
C5XTASY
That one worked. Thank you.
Ed
Old Oct 12, 2005 | 07:22 PM
vetpet's Avatar
vetpet
Default Katech Ported TB
I was on their site but couldn't find anything about their ported TB. Do you need to call them up about getting one done? Did they do yours or was it on an exchange basis? I may be in the area soon and would like to pick one up.
Old Oct 12, 2005 | 08:13 PM
yankeevetteconvert's Avatar
yankeevetteconvert
What are the specs of your cam ?
Old Oct 12, 2005 | 09:44 PM
C5XTASY's Avatar
C5XTASY
Call up the Katech website and hold your cursor on "Street Performance" and then click on "Engine Products" when it comes up. Scroll down to "Throttle Bodies" and click on it. Voila!
Ed
Old Oct 13, 2005 | 07:17 PM
vetpet's Avatar
vetpet
Thanks Bro for the help. My eyesight isn't what it used to be!
Old Oct 17, 2005 | 12:46 AM
Vette#2's Avatar
Vette#2
Cam is stock but I have Yella Terra 1.8 shaft mounted roller rockers which add about .030 lift to the cam. I have notice that after the EMC adjusted the idle went back to what it had been, but still has a slight lope. The big difference I'm noticed is mid range torque, seems to have punch when I get on the Freeway.
Old Oct 20, 2005 | 09:00 PM
ROD BROWN's Avatar
ROD BROWN
Default Throttle Bodies
I have read so much about throttle bodies on the Forum that I am really confused.Some say its a waste of money and some guys say they got real great results from this mod.I wish I knew some one in the area that would allow me to borrow an extra thats been modded so I can get the real scoop.I am not saying these guys are fibbing,but there is an never ending debate on T.B.'s.I would like to try one just to satisfy my curiosity.Question: Do you need to reprogram my computer with this mod or will the computer automatically compensate for the additional air?
Old Oct 20, 2005 | 09:46 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Which TB? 78MM or LS2 90MM?
Old Oct 21, 2005 | 12:52 AM
Vette#2's Avatar
Vette#2
The ported ones are 78mm standard GM TB's.
The compuer will "learn" this change in about 100 miles. I'm told no need for a retune, per Shawn & Kirk.
Katech claims 5-6 hp on a stock engine ...........
To Installed ported T.B. WOW
Old Nov 1, 2005 | 03:15 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
Thought you guys might like some flow data
enjoy
LS1 THROTTLE BODY FLOW SHEET
Stock LS1 throttle body: 526-529 cfm @ 10” / 880-885 cfm @ 28”
Ported LS1 throttle body: 559-566 cfm @ 10” / 935-947 cfm @ 28”
Old Nov 1, 2005 | 06:20 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
enjoy
Any numbers for a ported LS2 90mm unit?
Old Nov 1, 2005 | 08:48 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
how about track times other than seat of the pants! anyone
