Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
1/4 time needs to improve
Old Oct 16, 2005 | 09:26 PM
splidecision63's Avatar
splidecision63
Just got a 98 vette and ran a 14.20 102 mph. I see some of you are running in the high 11's 110+ mph. What can I do to improve????
Old Oct 16, 2005 | 10:32 PM
Mitch C's Avatar
Mitch C
Before we can give you advice we need more info. However even without knowing anything about your car I can tell you 14.20 is sub par
if your track is at or close to sea level. A 102 MPH trap speed is in the normal range for a bone stock A4 with 2.73 gears.
Is your car an A4 or M6?
If it's an A4 which rear do you have 2.73 or 3.15.
What was your 60 ft time?
What mods if any does your car have.
Old Oct 17, 2005 | 06:07 AM
laron's Avatar
laron
AGREED...
A 98 a4 w/ 2.73's should be able to hit 13.6 off a 2.1 60 ft BONE STOCK on a close to sea level track...
Since you did trap 102 ( about normal for an 98 a4 ) the problem is more than likely not your car or your track....
It's your 60 ft....
The first time I ran my A4 2.73 2004 vette at the track I ran a 14.2
My second run was a 14.1
My best run on my first night out was only a 13.9
I WAS SOOOO DISAPOINTED
Then I came to this site and learned ....
-PUT THE CAR IN 3
-TURN TRACTION CONTROL OFF
-LAUNCH SLIGHTLY ABOVE IDLE
-TURN AC OFF
I went back to the track with these new techniques and cut a 13.6 at 103 my first run
Ended up running 13.5 Bone Stock......
I dropped a solid 1/2 second but just learning how to actualy run the car..
Hope I helped
Old Oct 17, 2005 | 11:27 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Originally Posted by laron
AGREED...
It's your 60 ft....
-PUT THE CAR IN 3
-TURN AC OFF
Hope I helped
Great post!!! Give it a try and let us know how it goes!
Dave
Old Oct 17, 2005 | 10:02 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
There's no way your car in stock trim will run 11's...
You'll need to mod pretty heavily, then learn how to drive those mods....
Ron
Old Oct 17, 2005 | 11:27 PM
Slow Vette's Avatar
Slow Vette
Old Oct 17, 2005 | 11:33 PM
Slow Vette's Avatar
Slow Vette
AGREED...
It's your 60 ft....
-PUT THE CAR IN 3
-TURN AC OFF
Hope I helped
DAMN! the first time i went down the track with the traction control on, ac on, launchin on idle, and in D, i did a 13.3@105 stock (02 A4 2.73) . now with just an intake im doin 13.0's launchin on idle. hey laron have u dyno'd ur car yet ? i managed 304rwhp and 314rwtq with my intake on a hot day
Old Oct 18, 2005 | 12:45 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Ron
Old Oct 18, 2005 | 01:20 AM
simpleman68's Avatar
simpleman68
Originally Posted by WALLstAL
That's how you tell 'em now brutha!!
Scott
Old Oct 18, 2005 | 08:48 PM
laron's Avatar
laron
I dynoed 299 rwhp and 309 rwt BONE SOCK on a dyno jet smoothed and SAE corrected....
All tracks are different....Stock 02 Z06's run 12.9-13.2 at 109-111 mph at my track...
My 13.5 will beat everything at my track Besideds Cobras (13.4 average) Z06's (13.0 average) Vipers (12.8 average)
To put the different tracks argument into a even better perspective...
I dropped a 04 LS6 head and cam into my Vette and a Vararam....Dynoed 345 rwhp totaly smoothed and SAE corrected and still only average 13.1-13.3 with an average mph of 106 mph......I have hit a 12.9 at 108.5 mph but it was a one time thing...Not an average wich is much more important...
At your track Id probaly be running 12.5-12.7 on average.
But he trapped 102....Wich at MY track would be average for a 2.73 a4 C5....So I beleave at his track he can pull a mid 13.
Old Oct 18, 2005 | 10:51 PM
Slow Vette's Avatar
Slow Vette
if all those other cars are running those times, then ur ok. btw whats the DA over there?
To 1/4 time needs to improve
