Here is an 04 Z06 that came in for a set of long tubes and a cam. We got a chance to put him on the dyno first for his baseline, then did all the mods to the car to see what we could come up with. Here are the results. Cam is a 228/228 113lsa. Stock heads, LG long tubes, borla catback. He actually came in with the catback and the vara ram intake already, so we only added the headers and the camshaft. Enjoy.
I recently had a chance to get on a dynapack. It seemed a bit more civilized then the dynojet.
How would you compare sae dynojet #s to sae dynapack #s?
Again, good looking curves!
JB
Hard to say because the dynapack is not affected by gears, it gives you what the car is realy doing, which is how it should be. Now say you change up how the car moves ont he dynojet, then you might either gain or loose something. Unfair way to evaluate a change in tuning if you ask me. Plus no tires to affect anything also. Its nice, because I can tell when I make a change in the motors program, and you can see when it gets difficult to make more power as you hit the limit.
I also like the fact that I can tune cell by cell very accurately.
So how did you like the features of it?
Rick
It seemed to be easier on the belts, and more detail orientated!
[QUOTE=Synergy Motorsports]Here is an 04 Z06 that came in for a set of long tubes and a cam. We got a chance to put him on the dyno first for his baseline, then did all the mods to the car to see what we could come up with. Here are the results. Cam is a 228/228 113lsa. Stock heads, LG long tubes, borla catback. He actually came in with the catback and the vara ram intake already, so we only added the headers and the camshaft. Enjoy.
Numbers look similar to mine. I like the format in the end. Very nice.
Numbers are very similar to mine. I like the format of the results. Very nice.
It's hard to make heads or tails of that sheet. Can a dynojet-like sheet be made? You know, torque/hp numbers in one frame, A/F in aother. Much easier to compare that way.
I will try and get one up when I get back in on monday.
Because the dynapack doesnt read high enough for cars making real power...
So you are saying that 1100whp and 3000lb/ft wtq is not "real power"
At any rate, it solves the problem of tire spin on the dyno for high rwhp cars as well. Sounds like the real reason that many go with Dynojet over this is that most other shops have Dynojet as well
You are correct on the really high hp drag cars. There is dynopak that can go 2,400 rwhp. Well beyond any conventional dynojet. Although 1,200 rwhp is do-able for most.
Again the numbers are dead accurate when compared to dynojet (that is not being pushed).
