99 Corvette Vs 94 Z28
My friend and I were curious. How can we tell what gear that vette has in it. It has 1-2-3-D. Does that mean it has a 3:15? I know in the Z28's if your car has 1, that means you have a 3:23. If not, you have a 2:73. If anyone knows, i'm curious. I know this information, because I called the dealer on it. Thanks for the help. Also, what do you guys think about the race?
The Z28's mods are LT headers, matching Y-pipe, LT4 KM and a Moroso CAI.
Id say more than likely he has the 2.73's....
Just because they made a lot more 2.73 C5's than 3.15's....
Im sure some one will post the code for the 2.73 and 3.15 gears shortly...
The average ET and mph for the 2.73 A4 C5 is 13.5 at 103 mph...
A 3.42 mn6 LT1 with long tubes and cold air intake should run around the same times.....
Since they tend to run high 13's / low 14's bone stock.....
Keep having fun on those closed courses
I dont think your car running a 8.4-8.5 1/8 mile would put it at 13.1 in the 1/4...If anything, I would imagine your car would come out quicker in the 1/8th, then die down top end....Thats why a 13.3-13.5 seems more reasonable.
Also, I just raced a vette 0-120 and he didn't pull up top. Which means my MPH should be around 103 or so...The vette should have pulled up top, if in fact it was faster top end. Were talking about going 103 and I was in front to 120. I'm confused why my idea of running a 13.1 is so farfetched? Just because you don't have an LT1, doesn't mean it's unrealistic for one to run a low 13 with basic bolt ons. lol, do you think I'll run 83 MPH in the 1/8 and then run 99 in the quarter?
I guess that would be a little hard, since the car ran 99 MPH in the quarter stock...By the way, I have a stock 3:23 gear on the car. I called the dealer.
Exact mods = LT headers, Matching Y-pipe, Moroso CAI, aftermarket intake elbow, high volume oil pump, descreened MAF, (that does nothing) LT4 KM and 160' thermostat. I just mentioned the mods before that "actually" do something. The other mods I listed, don't add any HP gains at all...The car also just had a new crank put in. The timing chain broke and to make a long story short, I ended up needing a new crank. Three valves and a pushrod ended up getting bent.
My 2.73 a4 dose 8.5 in the 1/8 and then 13.0 in the 1/4....
DOSE THE LT1 REALLY DIE THAT HARD UP TOP???
Therefore, the vette I raced must trap 100 in the quarter or maybe slower...
A stock LS1 vette A4 with 2.73 gears is somewhat of a a dog. The gears "really" kill it. It's a low 13's car though. My friend's dads 97 A4 car ran a 13.2 stock.
steve
steve
By the way, thanks a lot for seeing my point. I'm glad someone else stood up for me and has had experience with these cars.
And to your original question poster, "How to tell what gear the vette has", on the glove box is the options and if it has 3:15 performance axle, it will have G92 code!!
Don't be so skeptic about Lt1's, they are great performing cars, and with his mods...easily done!!
Thinking about sending my dad's mostly stock 94 Z's PCM in and seeing what gains it can get. Well.... mainly it's got a couple issues I think. LT1's can be strong cars for what they got. My 95 Z would take out my 92 LT1 C4 mainly due to the gearing. The vette was 2.59 gearing and the camaro had 3.23's... I had both cars at the same time and we took em to the track to run heads up. The camaro pulled out on top each time....hehe..
Like I said again... a "stock" 2.73 geared A4 C5 is a kinda a dog..
103 mph for a C5 is almost laughable...
The quickest 2.73 that I know of ran a 13.1 at 107 mph...
90% of them are 13.4-13.6 at 102-104 mph....
Slow for a Vette but still not really what most consider slow.
I think a 2.73 geared C5 would only be 5 tenths quicker than a 3.23 geared LT1 camaro....
A couple of mods will make that up real quick...
No big deal for the maro to gain 5 tenths...
One poster said that his Lt1 camaro would beat his LT1 C4 down the 1/4 mile....
The C4 had 2.59 gears...
The camaro had 3.23 gears..
Thats a .64 differance and made the camaro gearing much more agressive....
It would be like comparing the camaro and it's 3.23 gears to a C4 with 3.87 gearing.....
