Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Exhaust Mod
Old Feb 23, 2006 | 08:53 PM
vettejockey's Avatar
vettejockey
Default Exhaust Mod
I have just purchased a 2003 conv with an automatic transmission. When I bought the car I was not aware how much horse power is lost with the auto trans. To improve performance I am wanting to go to a Corsa exhaust system with X-Pipes. While I am installing this mod I want to put in a High Flow cat I am just not sure which ones are compatable If anyone has any information I would appreciate the help.
Randy
Old Feb 24, 2006 | 06:26 AM
Mitch C's Avatar
Mitch C
Randy
You will gain VERY little added performance doing a catback, high flow cats and X pipe. Do it for sound and looks NOT performance. The A4 tranny is not the problem. If your A4 has disappointing performace more than likely you have 2.73 gears. Check the door of your glove compartment. You will see a tag with the build codes for your car. If you see G92 you have 3.15 gears if you don't see it you have the standard 2.73s.
If you really want to wake your car up install a Yank SS3200 and 3.42 gears. Your car will perform like you added 100 HP.
Old Mar 4, 2006 | 02:14 PM
vettejockey
Thanks your information is exactly what I experienced. The sound is worth the investment anyway.
Randy
Old Mar 5, 2006 | 05:49 PM
Wake Champ's Avatar
Wake Champ
Default codes
I have checked and cant find any codes listed on my car inside the glove compartment. Can you be more specific? Sorry, it is my first vette. Thanks-
Old Mar 5, 2006 | 06:09 PM
Wake Champ's Avatar
Wake Champ
nevermind, I found it in the side compartment
To Exhaust Mod
