Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
BFG Drag Radial vs ?
Old Jun 7, 2006 | 09:00 AM
Icevettez06's Avatar
Icevettez06
Default BFG Drag Radial vs ?
I have been using BFG DR 315*35+18” Best et is 11,55 @119,9 ,60fet 1,8sek are there any other tiers 18” better than BFG. I´m adding 100 hp wet NOS. Will I smoke the tiers? Any on know what kind of ET and MPH to expect.
Ingó.
Old Jun 7, 2006 | 09:19 AM
robz's Avatar
robz
Ingó.
You will have enough tire to be in control but you will spin and lose some et along the 1/4. What are your mods? It seems like you have around 430rwhp. With 100 shot you should be in the mid-high tens on a good launch/track/shifting.
M&H and MT both make a drag radial that will hook better than the bfg dr. It seems the tires you have still have more in them.(1.6x). Work on your launch technique to squeeze out more et. Your likely giving up .4 or more just on the 60ft.
Your mph should be 130+ with 100 shot on top of you setup.
Give us more details.
Old Jun 7, 2006 | 11:21 AM
Icevettez06
Mods are 425RWHP Z06 2002 heads are CNC stage3+rockers+cam+heders+Xpipe+BlackWin g
Ingó.
Old Jun 7, 2006 | 03:28 PM
robz's Avatar
robz
Ingó.
Then I guessed well. lol Let us know how you do. I'll stick with my predictions.
Old Jun 8, 2006 | 02:38 PM
Icevettez06
I will let you know.
Ingó.
p.s. do those tire M&H and MT com for 18"
To BFG Drag Radial vs ?
