Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
c6 z06 VS procharged c5
Old Jun 21, 2006 | 07:20 PM
MRC5's Avatar
MRC5
Default c6 z06 VS procharged c5
hey guys ...
would do you think a bout this race ..?
new c6 z06 stosck VS procharged c5
c5 modifications : (( forged engine 347 ci - ported heads -cam 224/228 581 /114 - A&A p1 procharger 12 psi. 42 injectors. racetoinx fuel pump.z06 intake . TB headers . off road x pip//e . slp loud mouth exhaust . 3.42 grear. 3200 stall .trans go kit shift . wethanol injecion .
is there any chance to catch the z ???
Old Jun 21, 2006 | 07:59 PM
JR_VET's Avatar
JR_VET
Originally Posted by MRC5
hey guys ...
If it is stock or lighly modified you will walkover it.
Old Jun 21, 2006 | 08:14 PM
chriswtx's Avatar
chriswtx
The Z will be trying to catch you...
Old Jun 21, 2006 | 08:25 PM
Ranger's Avatar
Ranger
Outcome depends on the relative driver skills and the venue.
Ranger
Old Jun 21, 2006 | 08:59 PM
torchvette10's Avatar
torchvette10
In a quarter mile, yes the driver will make the difference (even if your car is for sure supposed to be faster, but a bad driver in a Procharged C5 is gonna loose to a good one in a C6 Z, but if both are good the C5 wins)
then if you do a 60-170 run, then you will walk away for sure!
Old Jun 22, 2006 | 04:28 AM
MRC5's Avatar
MRC5
woooooooow...thats make so proud ....to kill my lover z
Old Jun 22, 2006 | 01:49 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I been there and done that on the road already with a new Z and to several unsuspecting Vipers and a set of HYbusa's who were really shocked
Old Jun 22, 2006 | 04:16 PM
bandit_99's Avatar
bandit_99
Ranger
Bingo.
Old Jun 22, 2006 | 04:20 PM
Ranger's Avatar
Ranger
Had that car to a drag strip yet? If so, what times/traps did it run?
Mine has run 6.31 in the 330'-1320' at a 1800' DA, but due to Torque Management the car won't launch hard.
As a point of reference, the two fastest C5Z06 H/C cars with 470-490 rwhp run 6.20-6.25 for the 330'-1320', at a slightly negative DA.
Ranger
Old Jun 22, 2006 | 04:42 PM
torchvette10
Hi Ranger,
I think we can't compare Peterpan's car with a stock C6 Z since his car makes 742 RWHP! I will answer for you Steve (sorry, I hope you don't mind). He s not a track guy! He built his car mostly for the street that's why his slips might not reflect the real capabilities of his car (which would run mid to low tens on good tires and a good lunch)
Old Jun 22, 2006 | 04:56 PM
Ranger's Avatar
Ranger
Hi Ranger,
That's one of the interesting things about high rwhp cars. Very seldom do the run times that are proportionate to the power they have. This is generally due to traction and power-band issues. In Peterpan's case, the traction issue is reduced by his auto tranny. But he also loses some power to the tranny. Still interest in the times, if he has any.
Ranger
Old Jun 22, 2006 | 07:15 PM
torchvette10
Ranger
He has a manual tranny.
Peterpan,do you have some times??
Old Jun 23, 2006 | 09:04 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I call on the Hayabusa comment. It takes a vehicle weighing 3000 Lb, close to 800 HP to run with a stock Hayabusa. Don't ask how I know. Mine is slightly modified and cranked it up to 204 MPH with a little more to go, but was running out of road.
Old Jun 23, 2006 | 09:54 PM
jers98vet's Avatar
jers98vet
SAAWEETT!!!
Old Jun 24, 2006 | 12:36 AM
chriswtx's Avatar
chriswtx
No BS there. Peter Pan makes 750wrhp at 6000rpm and weighs in at around 3250lbs. Thats around 875+hp at the motor...His car just plain out hauls butt..Seen it in person...
Old Jun 24, 2006 | 12:49 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
On pure street rubber and off idle launches I can only hit 12.1 trap 135 and spin until 1/8 no matter what I do. Two reasons I do not put some slicks on this are that I still have 2 stock items left as the mod budget only went so far and those are very important for a MN6 to play at the track and launch. The mods I still need so I can launch my beast are the RPM tranny and DTE differential I need and currently saving for as they are not cheap.
As Tourchvette has stated I am not a 1/4 guy and so far my tranny and differential are holding up on the street as I am not into slamming the gears hard or do I have to worry about launches as this thing spins until 4th on take offs and this is a blast.
Yo can call all you want, but I will tell you at 70 in 3rd and mashing the pedal my car goes up in something called tire smoke and then it grabs and is into another zone. Look when I did this to the bikes this was from around 70 and they got about head until I got my rears to hook as then I was compeletly in the boost band and this is one time on the street that I saw 12 lbs of boost and did a normal shifting as I did blow by them at about 100 and shut down at 130. They stopped me and we talked about it and I was surprised myself, but when you have Sick HP broken in I had over 3k on the setup then you will know what I mean. If I was to run them from a stand still, I would have no chance on the street as I would just go up in smoke to long while they would blow me away. Oh there is nothing like having a Vette that when you are cruising along at 100 you shift into 4th and get wheel spin, I about crapped my pants when this happened to me the first time and now it just puts a smile my face
FI is addictive as I bet it is driving a kick *** street bike
Old Jun 24, 2006 | 12:59 PM
Ranger's Avatar
Ranger
Thanks for the details, peter pan. Seems that you are following a prudent course to get where you want to be. Doing that without breaking parts is always an accomplishment. Rodney and DTE are good choices.
Ranger
To c6 z06 VS procharged c5
Old Jun 24, 2006 | 02:57 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Ranger
Thanks, I new going in I would need a new trans/diff and so that has gone into the factor of why no slicks. Sure I put in Hardened output shafts and DTE brace those are band aids at best. One thing about my setup that surprised me was that we figured 650 rwhp, not the 742 that we got and I had my tuner shut down the dyno at 6200 and that is where my rev limiter is. As most know in the SC world I have left some on the table (setup is built for 7000) and I did this as we passed my modest goals, plus what I have is more than enough at the moment and I want the motor to last for quite sometime.
One of the things I really like about this setup is I can take it out and abuse it for extended periods of time as I have the rev limiter so low and it is still so much fun. There is nothing like coming out of turns in 3rd at 70/80 and mashing the go pedal and getting slammed back in the seat and launching forward. Reminds me of times in an F-16 on launch or a blast in Afterburner when coming out of turns, it is such a rush
I will be taking it out today on a cruise with the club so I can get some sustained fix (boosted runs) and then go eat
Old Jun 24, 2006 | 07:58 PM
Sponge Vette
Very Nice, Not to many cars that can hang with a bike
Old Jun 24, 2006 | 11:58 PM
gingerls1girl's Avatar
gingerls1girl
I noticed that you have a blue hose connecting your air mass sensor to your throtle body. I have a stage 2 procharger on mine and am trying to locate a red one for that location. Can you help? gingerls1girl.
