Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
01 C5 dyno numbers?
Old Aug 13, 2006 | 09:14 PM
smknvette's Avatar
smknvette
Default 01 C5 dyno numbers?
Hey guys, just left the dyno and finally ran my car for the first time. I don't know if the numbers are right or not. I have a haltech TRAP intake, B&B bullet exhaust, and a programmer. My car is a automatic with a 3.15 gear. My numbers were
max hp-303 max tq-311
max hp-293 max tq-331
max hp-306 max tq-326
does this sound about right for what I have? The AFR is stright on 15. Do I need to change that with the programmer?
Old Aug 13, 2006 | 09:30 PM
JR_VET's Avatar
JR_VET
First Of all WHO Dyno the car? the Afr is way too lean and those are great stock numbers
Old Aug 13, 2006 | 09:33 PM
smknvette's Avatar
smknvette
A new shop that just opened here in town. I run the fuel up on the programmer to +7 and the afr didn't move much.
Old Aug 15, 2006 | 12:17 PM
CarsRFun's Avatar
CarsRFun
15afr is not safe... take your car to CAM and get a good tune.
Old Aug 15, 2006 | 12:34 PM
smknvette's Avatar
smknvette
where is cam? what is it.
Old Aug 15, 2006 | 05:26 PM
CarsRFun's Avatar
CarsRFun
http://www.carolinaautomasters.com/
Jeff is DA man when it comes to a tune.
Old Aug 19, 2006 | 02:44 AM
SLPRC5's Avatar
SLPRC5
have the other tuner mentioned do a tune... Numbers do look fine.
"As a reference, I've seen a bunch of Vettes dyno'd at all the Dallas shops. A bone stock '97 auto will do about 285-290. A bone stock MN6 will do 10-15 more. A bone stock Z06 will do about 352".
Mr. Wrench
SC5
Old Sep 8, 2006 | 11:00 PM
Dyno Dan's Avatar
Dyno Dan
15 - 1 AFR = holed pistons real quick.
More info needed to know if this is a correct reading.
Old Sep 9, 2006 | 07:52 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
Default Huh?
So, based on all that, you have just about 415 at the crank. you have nothing to fear from C6 cars, they dyno approx 340. "
How? He's pulling 306rwhp in an A4 and you say he has 415? He's got ~366 crank hp at the most with generous 20% drivetrain loss.
Old Sep 9, 2006 | 10:57 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
new tune ... my car when stock a4 with 2:73's with just a tune and black wing made 315
Old Sep 22, 2006 | 04:21 PM
smknvette's Avatar
smknvette
Been a while since I looked at this one.lol Found out my AFR was wrong. The guys computer was messed up. When I found this out I put everything back to the way the programer comes from the factory and the car now runs better. My budies turbo supra has a wide band on it and his car had the same reading on the computer, but his WB was correct. I belive his was right (he made 706 RWHP). I was about ashamed to run my car after his. But it was fun!!!
Old Sep 22, 2006 | 11:19 PM
SLPRC5's Avatar
SLPRC5
Sorry for the misunderstanding, that last sentence was referring to my car having 415 at the crank..I should have omitted it.
Old Sep 25, 2006 | 09:53 AM
David426's Avatar
David426
Yep, thats correct... It also helps to know what type/model dyno was used and what calibration was used also. SAE Corrected or not?? I've seen numbers all over the place on this forum, because different shops use different callibrations and equipment.. So when a person posts dyno numbers and gives no more information its like comparing oranges to apples
Old Sep 29, 2006 | 05:35 PM
grandaddy's Avatar
grandaddy
Old Oct 8, 2006 | 02:29 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
My 98 a-4 3:15 car with a catback and vararam intake dynoed 304 at A+A corvette's party.
I would say that is a decent number for your car
I do not know what kind of dyno they have,but I assume they are adjusted numbers.........I think A+A would only have /do the best
Old Oct 15, 2006 | 09:23 AM
D C's Avatar
D C
USMC (retired)
Thats not bad power for an A4. Andy, Charlie and crew at A&A did some magic on my 3:15. Check the sig out....I am very happy with it.
Old Oct 15, 2006 | 07:05 PM
Evolution's Avatar
Evolution
To 01 C5 dyno numbers?
