new best last night finally hooked up 1.484 60ft. 1/8 mile 6.620@104.50 10.364@132.97 had to go to 28x11.50x16 tires to get it to hook now time to step it up a little more try to get into the high nines
402 Stroker fast 90/90 edlerbrock wcch heads 232 240 595 605 comp cam 150 nx dual noozle wet nitrous 373 gears dte brace 3200 vigante stall that is to loose qa1 adjustable shocks 28x11.5x16 hoosier quick time pros.
Like we've been saying~ Those QA-1 shocks are the real way to go to let the suspension work with your car's launch, instead of against it- especially to hit those tight 60 ft. times!
dam good numbers. I sure would like to talk to you about you gear and shocks
My buddy has the track rented nov 25 if you want to come play with us they will be about 10 vetts with us and a bunch of mustangs give me a call when you got time Robbie 706-936-0774
Don't forget to trim or remove your wheel well liners with the 28's.
Thats is the first thing i did before i put the wheels on and it dont look near as bad i thought it would. if anyone having problems hooking try 28's it will help.
