Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Sooo, what would I trap?
Old Mar 8, 2007 | 07:56 PM
Y2KRoadster's Avatar
Y2KRoadster
Default Sooo, what would I trap?
I have an 01 couple boosted on 8 PSI going through a 3.73 gear and it's a 6-speed. The car put down 540/455 on the dyno. Lets assume that the DA is normal conditions (whatever that may be...I'd like to know that as well if anyone does). I am having an arguement with some friends and they don't think I can trap 130...
Old Mar 8, 2007 | 08:36 PM
tlaselva's Avatar
tlaselva
Your a little shy to make 130mph easily.
If the conditions are just right, you have some experience and willing to pound it down the track, you just might.
Old Mar 8, 2007 | 08:38 PM
MotleyDrew's Avatar
MotleyDrew
My guess is that your numbers are probably from a Dynojet Dyno right?
You should be around 123 - 125 ish. Nothing to be mad about !
Old Mar 8, 2007 | 10:07 PM
Dainbramage's Avatar
Dainbramage
I would think you'd be all over it if you can drive it right. Heck, the new Z06s with 450-460whp are trapping in the 125-128 range.... maybe I'm missing something?
Old Mar 9, 2007 | 08:26 AM
msghuff's Avatar
msghuff
I would think if your making 50 more RWHP than me you shouldnt have a problem....
Old Mar 9, 2007 | 01:28 PM
itchynackers's Avatar
itchynackers
Old Mar 9, 2007 | 01:36 PM
nickolbag's Avatar
nickolbag
I say 129.9. ooooh so close. Maybe its time to up the boost. Just go take it to the track and run it until you get the mph you want on a slip. Then you have proof but I say it can be done.
Old Mar 9, 2007 | 05:11 PM
OneBadCEZo6's Avatar
OneBadCEZo6
Im thinking 132mph with awsome weather..
Old Mar 9, 2007 | 06:39 PM
Fartpipe's Avatar
Fartpipe
My 440rwhp M6 car traps 123mph leaving on and off the gas on street tires in ok weather. I would think with the extra Hp your car has pending you havent added alot of weight is going to trap 130mph on a clean pass with ok weather. Saying you have traction, good shifting, not alot of weight in the car etc. Good luck and keep the RUBBER SIDE DOWN!
To Sooo, what would I trap?
