99 frc lg lt no cats ti catback, vortex intake, ported tb last night i ran a 8.39 at 88.0 mph .600 reaction with a 2.111 60 foot. how much lower could i expect my 1/8 time to drop with a lower 60 foot. and what should i be able to run in the 1/4. thanks for any info and any hints on gettin the 60 foot down would be great.
My stock 99 frc with airbox and catback, runflats!
Seems like you were on pace to run around a 12.7 in the 1/4. As for the 60' what tires are you using? On a street tire with practice you should be able to get that 2.1 down to the 1.8 range. That should be good for around a 12.3 in the 1/4 for you.
My 99 FRC with only longtubes, 3" duals with bullets,no cats and a RAM PowerGrip HD clutch went 8.2 at 89 mph. I ran between 8.4-8.2 all night with no burnouts or power shifting.
+1 on the mid 12s. I have found that some 1/8 mile tracks do not have the track prep that some of the better 1/4 mile tracks. At my home 1/8 mile track I was running 8.2-8.3 @ 90 with consistent 2.0 60' times, but on an NHRA track that was prepared well I cut a 7.8 @ 92 MPH. That was with a 1.8 60' time which ought to give you an idea of what you can do if you can get your 60' down to the 1.7-1.8 range. Only you can judge the DA and other factors of the track you are running but you might just get on a well prepped 1/4 mile track and cut a 12.40 @ around 110. On the other hand you could find your 1/8 mile track is better prepped than the nearby 1/4 mile tracks. You got .3-.4 to gain on that 60' and you will be tough.
For every 1/10th you can cut off your 60' you should pick up 2/10ths in your ET......at least that is typically the way mine performs.. THis weekend I had a 1.43 60' and a 6.61 @ 105 on a 150 shot. Changed to 125 shot and got 1.55 60' with a 6.93 @ 101....Its not exact of course but your 60' is EVERYTHING when your running just an 1/8...What tire you running? M/T et streets will HOOK UP!!!!!!!! 17" though
