Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Shifter problems....
Old Apr 26, 2007 | 09:28 AM
lodilobo's Avatar
lodilobo
Default Shifter problems....
Which is the best shifter out there? I made the mistake of replacing the stock one with a Hurst.....it sucks...could not get in 2nd at test and tune.
Old Apr 26, 2007 | 01:02 PM
MGorman's Avatar
MGorman
The Hurst is one of the best shifters out there. Some people don’t care for them, but I’ve never heard of anyone having a problem shifting into 2nd gear with the Hurst. Are the stop bolts properly adjusted? If the bolts are not properly adjusted, or have come loose it could cause difficulty in engaging 2nd gear.
If you totally hate the Hurst, you may want to try the C6 Z06 shifter. People seem to like it as an alternative to the Hurst and B&M shifters.
Old Apr 26, 2007 | 01:52 PM
nickolbag's Avatar
nickolbag
I have the Husrt shifter and will say it's notchy at best but I have never had a problem getting it in gear. It just takes a little more effort than a stock one. If if won't go into gear there must be something wrong.
Old Apr 26, 2007 | 02:43 PM
lodilobo's Avatar
lodilobo
Maybe this is just a defective one. Back in the 70's, when I use to street race old Chevys you couldn't beat a Hurst. Any common trans. problems that could cause this? 3 times straight........would not go into 2nd, it was jammed in the neutral position...finally got it into 3d...still recorded 119mph. If I drive any where and shift normally, it works o.k. still not smooth, though.
Old Apr 26, 2007 | 03:34 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Either it's the stops or you trans I'd say...
Old Apr 27, 2007 | 03:45 PM
BoostedBlkZ06's Avatar
BoostedBlkZ06
i had a hurst shifter and tried everything and couldnt get into 2nd or reverse sometimes and it felt like crap, changed to a kirban and feel SOO much better.. take al ook at kirban great design and feels smooth shifting and still nice and short
Old Apr 27, 2007 | 04:08 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
I have the B&M Ripper and have yet to miss a gear in it. I love it to death.
Old Apr 28, 2007 | 07:54 AM
lodilobo's Avatar
lodilobo
Thanks for the input.....I have ordered a new B&M Ripper. Interesting that someone else experienced exactly the problems I did with the Hurst.
To Shifter problems....
