Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Which Tranny
Old Jun 14, 2007 | 02:13 PM
ctvette2003's Avatar
ctvette2003
Which Tranny
Ok guys i know nothing about this at all so i need the experts to step in. My stock tranny is getting ill (popping out of first). So i am looking to upgrade. I have been looking at RPM but was wondering where else i should be looking? Oh i have an o3 coupe MN6 645rwph (for now) Any help will be much appreciated! TIA
Old Jun 14, 2007 | 04:19 PM
ctvette2003
Ttt
Old Jun 14, 2007 | 04:39 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
call Rodney at RPM
Old Jun 14, 2007 | 09:23 PM
sixspdvet's Avatar
sixspdvet
Rpm...
Old Jun 17, 2007 | 06:51 AM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
You can't do any better than RPM.
Old Jun 18, 2007 | 07:35 PM
irun4cops's Avatar
irun4cops
Which is better, the z06 trans in an 02, or a 99 6 speed trans? My z06 trans has 2.73 gears. The 99 trans im looking at is built, and cryo gears and hard parts. It has the stock gearing which is 3.42 i think? Why is a z06 trans so much different to start with, and why is a 99 6 speed a better trans when running high HP? Is the z06 trans lighter weight? thanks
Old Jun 22, 2007 | 10:53 PM
bogielake's Avatar
bogielake
no weight difference, Z06 1,2,3 gears are steeper for quicker acceleration down low, 4th is the same. With big HP you do not need lower gears. Call Rodney and get a built M6, run a 3:42 in the rear.
Old Jun 25, 2007 | 10:02 PM
irun4cops's Avatar
irun4cops
yeah, called rpm... im running a 2.73 right now, so im geared tall, which I like... dont have to shift as often, and dont have as much wheel spin. After talking for a while, what we came up with is... i need to switch out my 5th and 6th gear. Hes going to cryo everything that needs it, and 5th and 6th will be wider actual gears which can handle extra strain. Right now, he thinks my 4th gear gets to about 165-170ish, which sounds right, so 5th is currently getting me past 200, making 6th useless. He wants to put in a short 5th which would get to 190ish, and a 6th that takes me to 220 at 6800rpm if i have the power. That way my peak power is focused into those mph and rpm ranges so my car will climb faster. Im going to document how much it helps (video), ill be getting to 200 with the gearing i have now, and then with the upgraded gears, and see how much quicker it climbs between 160 and 200 with the new gears vs the old. They are also going to put in the HD output shafts, and do all the other stuff that they normally do.
Old Jun 26, 2007 | 10:29 AM
Mark-44's Avatar
Mark-44
Wow!
Just wondering what track you run on. Waiting for the videos.
Old Jul 9, 2007 | 12:45 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Originally Posted by 93Polo
call Rodney at RPM
hell yea! Great trany, and it looks too good to hide under the car Good luck man!
Dave
Old Jul 12, 2007 | 05:20 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
You'll like the tranny RPM sets you up with
Old Jul 23, 2007 | 08:00 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Another vote for RPM Transmissions (<- forum vendor).
I like my new Level V MN6 transmissions matted to a set of DTE 3.73 gears
Old Jul 23, 2007 | 10:37 PM
sixspdvet's Avatar
sixspdvet
RPM all the way,, M6 with 342 or 373 will work just fine..
Good luck...
Ernie
Old Jul 28, 2007 | 06:45 AM
SilverBulletZ06's Avatar
SilverBulletZ06
6th gear is a waste of space for the area I live. Every time I actually get to a point I can put her in 6th I need to downshift because of traffic. Depending on area, you might want to think about downsizing that.
To Which Tranny
