Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Drag radial tire ???
Old Jul 23, 2007 | 10:05 PM
LS1 REDBIRD's Avatar
LS1 REDBIRD
Default Drag radial tire ???
What drag radial tire will be best for me? I have a pair of Nittos 555r's (275/40/17) mounted on 17 x 9 C6 wheels. Also have a pair of BFG Gforce TA drag radials (315/30/18) mounted on 18 x 10.5 wheels. Looks like the TA's are a bit shorter in a side by side comparison. My best to date is a 12.87 with 1.89 on street tires.
Specs on my are are as follows:
2000 FRC MN6
stock clutch & rear
Kooks headers and cat X pipe
VaraRam intake
Old Jul 25, 2007 | 10:20 AM
TwoValveKid's Avatar
TwoValveKid
My older car (stang) had better luck on the BFG drag radials. Most people i knew at the time did too. Nitto is great for everyday mounted use from my experience. If you have a spare set go with the BFG's or even the MT radials. That is a nasty tire!
Old Jul 25, 2007 | 04:17 PM
Ranger's Avatar
Ranger
Only one way to know for sure is to test them both. But it's likely the BFGs will perform better.
Both tires will need heat from a burnout for the 60' and 330' to beat stock street tires. There's a burnout procedure and launch tips at links in my signature.
The Nittos need a very long burnout because their tread compound is harder than the BFGs. Suggest psi for both at 18.
Good luck. Let us know how it goes.
Old Aug 7, 2007 | 05:17 PM
Redvette_22's Avatar
Redvette_22
My BFG 295/35-18's on 10.5 rims have worked very good for me. I will be putting headers back on soon and will see if they can work as well as the ET Street Bias Plys worked.
Old Aug 7, 2007 | 10:10 PM
Zee916's Avatar
Zee916
Nittos are not in the same league as the BFG. Really no comparison IMO.
When I had my Cobra, the Nitto's would blow loose in 3rd at 60 w/ only 450rwhp.
The BFG's would YANK in 1st gear when I was pushing 600+rwhp. I would not buy the Nitto for drag use, only street use.
Old Aug 10, 2007 | 06:43 AM
LAYNLOW's Avatar
LAYNLOW
Has M/T released the 18" dr's yet. I know they were suppose to come out in June . . .
Old Aug 10, 2007 | 07:11 AM
Ranger's Avatar
Ranger
MT Street Radial List incl 18"
Suggest caution in selecting the MT 18". Watch the tire height. Also the R2 compound is very sticky. The bigger the contact patch is the tougher the job for the clutch.
Ranger
To Drag radial tire ???
