I Was Wondering If Anybody Has Trickflow Heads & Cam Results With Automatic. I Have A 2000 Corvette Auto With 3:15 Rear End. I Read In Some Corvette Magizine That They Were Putting 550 At The Flywheel. If You Take 15% From 550hp
That Would Be Approx. 472hp To The Wheels. Does That Sound Right?
470ish RWHP is well within reason with a setup like that. Heres a post of a HC auto car with trickflow headsin that range.
Generally, the accepted loss through the A4 tranny is 20% and that equates to 440 RWHP - (440/.8=550)....and that is a very achievable RWHP with heads/cam combination.
I don't know what your combination could produce but to give you an idea take a look at my thread below:
it sounds possible but that is the high side of results. not many cars are going to achieve those numbers.
