Not bad numbers....dyno to dyno they all vary....so for a true ready if you could dyno the same 2 cars and you will see the difference there......if you take it to another dyno your read out will be different
Before extensive mods, my 99 MN6 with B&B catback, K&N, opened up oem airbox, no cats, Hypertech tune and O2 simulators = 337rwhp,338rwtq the tuner said that was the highest he'd ever seen with so few mods and "tune in a can"
dynos vary.. some shops use uncorrected numbers, some don't.. makes a BIG difference in results.. More than likely the previous owner had a dyno tune done.. Those numbers look normal for a tuned mn6 and blackwing.. Cat backs do nothing for rwhp other than sound
its actually about 15% for a MN6 and 18% for a A4.
15% drivetrain loss on a 345hp car means 293rwhp as opposed to 12% which means 303rwhp. Since 6 speeds dyno around 300-310 it puts them around 10-12% loss. This is on a Dynojet of course. If you are refering to a mustang dyno they will eat up a little more power.
Then why is there such a wide variance in numbers between different dyno shops?....and different dyno manufacturers?
Because they are machines and might not all be calibrated correctly. They can also be influenced by the parameters that the operators put in. There are plenty of "tricks" you can play to influence dynos as well as other factors. They are as standardized and accurate as they can be but will never be 100% accurate and consistent.
The equipment they use is a Dynojet Winpep 7 performance evaluation program. I know there can be variences between the different makes of dynos and if/how they compensate for atmospheric conditions - so I'm not taking the readings as a definate.. I was just happy that my "mostly stock" vette out HP'd all but 2 of the "heavily modified" vehicles that dyno'd that night
Someone mentioned that the numbers sound like a C5 with a "tune" on it. I'm not sure if he/she was refering to my car or one of the posts after mine - but I'm pretty sure the program is stock.
I was having some issues with pinging so I took it to a local Corvette shop. Well, long story short - they weren't used to working on newer vettes and screwed up the programming so bad that even the help desk for their programming software couldn't tell what they'd done. I ended up taking it to the dealership and having the stock programming put back on it. It hasn't been re-programmed since.
As for the pinging - I got ambitious one weekend and replaced the fuel filter and that seems to have taken care of the problem.
I was having some issues with pinging...I got ambitious one weekend and replaced the fuel filter and that seems to have taken care of the problem.
Lanna
Well for what it's worth, my stock, except for a blackwing and corsa catback, 04 automatic coupe, dynoed 291hp and 311tq.
Mine suffered from "pinging" problems too, and I finally got it to stop by having the computer professionally retuned.
The dealer said it was "normal" for it to ping.
As far as your dyno numbers, I don't really know what to think of what some of these dynos put out. Personally, I figure it's just a guessing game which someone should not put a whole lot of faith and credibility into.
A dyno is maybe a good tool for indicating how much of a difference some mods caused.....but even then, those figures can differ from one day to the next, even on the same dyno.
Awesome numbers. I understand most LS2s dyno around 330-340 stock... so that's quite impressive. With LTs, Corsa catback, CAI, U/D Pulley, NGKs I only got 374hp/372tq on my M6 LS2.
I recently had my 99 coupe tuned at Mid-America's funfest. The car is stock with only a Magnaflow exhaust. My baseline was 299.8. After the tune it was 313.4HP and 323.6 torque with 40,000 miles. My uncles 2005 coupe was only on the dyno for a baseline. His was 356.3.
Some of those other numbers sound a little exaggerated. What is basically stock? Not trying to cause trouble. It is what it is I guess. Wish I had turned those numbers.
Reason: Forgot something
