Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Important Question!!!
Old Oct 7, 2007 | 08:35 PM
sebesta1990's Avatar
sebesta1990
Default Important Question!!!
My friend recently traded his modified 2004 Z06 for a new 2008 Coupe. He gave me his stock intake manifold and throttle body to put on my 1999 Coupe. My question is, "Are the throttle bodies the same? Should I use his or just use my stock throttle body? Is there a difference?"
He also offered me his stock cam.
Any words of wisdom from the forum? Thanks.
Old Oct 7, 2007 | 10:17 PM
utryd2's Avatar
utryd2
No the TB is not the same as your stock one.....You have a very nice friend hooking you up with it......you would be paying around 400 bucks on here for them.....I would toss the cam in as well if you can do it yourself
Old Oct 7, 2007 | 10:23 PM
sebesta1990
Whats the difference in the thottle bodies? How will I benefit from the Z06 throttle body?
Old Oct 18, 2007 | 08:38 PM
KamiLos's Avatar
KamiLos
You make an extra 45hp
Old Oct 19, 2007 | 12:53 AM
JR_VET's Avatar
JR_VET
So how do you come up with 45 HP on a TB, Please explain? LS1 78MM TB and ZO6 also has a 78 MM TB and the same PN#. So please explain?
Old Oct 19, 2007 | 02:12 AM
KamiLos's Avatar
KamiLos
I was joking bro.
Old Oct 19, 2007 | 12:59 PM
nickolbag's Avatar
nickolbag
Personally if I were going to do a cam swap I would go bigger than an ls6 cam.
To Important Question!!!
