Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
WS6 same mods more HP!
Old Nov 19, 2007 | 01:02 AM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
Default WS6 same mods more HP!
Don't know what the hell is going on, but a buddy of mine has a WS6 with Kooks headers, just got a dyno tune, and is putting up over 360 HP. My 01 Coupe goes in for it's dyno tune tomorrow, but I'm starting out with 318 HP. Headers aren't going to give me THAT much of a bump up to match or beat his numbers. What the hell?
My car:
01 Coupe
6 speed
Halltech Stinger Intake
American Racing Headers
High flow cats
X pipe
Borla Stingers
His car:
02 WS6
6 speed
SLP intake
Kooks headers
after the headers unknown.
Old Nov 19, 2007 | 02:26 AM
evo2ls1's Avatar
evo2ls1
f bodys seem to put a little more down i think because vettes have more drivetrain loss
Old Nov 19, 2007 | 03:28 AM
GetSumZ06's Avatar
GetSumZ06
Yours auto and his stick? that would be a difference i beleive...
Old Nov 19, 2007 | 07:40 AM
Fartpipe's Avatar
Fartpipe
He says they are both 6spds.
I dont think theres a logical answer for that other than some cars do better than otheres and some dont.
Are you basing the dyno #'s off the same dyno, same day? There are some decent differences between just those 2 factors.
In my experience a Fbody 6spd loses approx 11-12% through the drivetrain and a c5 6spd loses approx 13-14% to the wheels. However the corvette is usually equal or better in some areas due to weight and aerodynamics.
Just go race him and have fun!
Old Nov 19, 2007 | 05:18 PM
spiral04's Avatar
spiral04
Originally Posted by Fartpipe
Are you basing the dyno #'s off the same dyno, same day? There are some decent differences between just those 2 factors. However the corvette is usually equal or better in some areas due to weight and aerodynamics.
The tune, as well as the things mentioned above could be the difference. I'm about to put my car back on the dyno next month since the weather is cooler and then see if I gain any hp. I'm also going to eventually try out another tuners dyno, just to see again if their are any differences.
Jason
Old Nov 23, 2007 | 02:02 PM
procs2v's Avatar
procs2v
fbody's are underated from the factory and don't have as much drivetrain loss.
Old Nov 24, 2007 | 12:09 PM
David426's Avatar
David426
There is more drivetrain loss due to the C5's independent rear suspension vs the F body's solid rear axle.. Also, there is more horsepower loss on an automatic vs a manual transmission.. Last but not least.. The WS6 and CamaroSS both have ram air with the same exact LS1 as the C5.. GM downplayed the horsepower ratings on the F bodys, so yes they are under rated... The F body has 150-175lbs of extra fat to push around and is less aerodynamic which makes up for the drivetrain loss at the track. Go to the track and it will be a good race.. I take dyno results with a grain of salt.. Members on this Forum have quoted Dyno numbers on a bone stock C5 from 270rwhp to 354rwhp.. Different dynos give different numbers.. There are also SAE, standard, and SAE corrected settings for the dyno operator to choose .. These settings make totally different numbers.. Take it to the track Jack
Old Nov 25, 2007 | 09:45 PM
C5XTASY's Avatar
C5XTASY
Jason
If your original dyno run was SAE corrected and smoothed, there should be no difference. The only time you'll see big differences is if a tuner is playing games with the dyno numbers by allowing the computer to see spikes, by not smoothing, not correcting for atmospheric conditions, etc., or, just fooling around with the software, and then calling that a large power increase after a tune.
Regarding the WS6, I guess I have a hard time believing 360 rwhp with just a set of headers. I've never seen so much BS in my life as people talking about their dyno results.
Ed
Old Nov 26, 2007 | 10:49 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
My car:
01 Coupe
6 speed
High flow cats
X pipe
Borla Stingers
His car:
02 WS6
6 speed
SLP intake
Kooks headers
First off, Dyno number mean NOTHING, the operator can make a dyno read whatever he wants, and different dynos will give different results.
Second, assuming a 15% drivetrain loss on a 6 speed, that would mean your buddy is makeing 414 crank horsepower, which is a 94 horsepower increase over the stock rated 320, no way headers alone are gonna give him 94 horsepower
Old Dec 5, 2007 | 11:17 PM
FASST LN's Avatar
FASST LN
I had a '98 SS Camaro that dynod 361-rwhp. I had intake, exhaust, GM hotcam, and LT headers. Your friend's car sounds pretty incredible and would be possibly the highest hp LS1 with just those modifications. This would lead me to think he failed to mention one of his modifcations to you or the dyno was not corrected for the weather and he made the pull on a cold Saturday morning.
FYI - There was no 'ram air' effect on the SS Camaro. Yes the plumbing was there and that is how GM marketed it, but the aerodynamics of the hood actually caused air to slide over the hood's intake.
I could wash my car and do a high-speed run to dry it off. Without fail, the hood would be completely dry except for some water drops in front of the intake because that is the only place where the air passes over the hood instead of along its surface.
I saw the same effects when it snowed on my car. All of the snow gradually blew off the hood as my speed increased, except for the portion directly in front of the intake. I miss that car.
Old Dec 5, 2007 | 11:31 PM
FUN LS1's Avatar
FUN LS1
His mods are accurate, its the dyno-mite brand dyno machine that is in question at this point.
To WS6 same mods more HP!
