http://www.totalengineairflow.com/ heres the website ive heard good things probably will be sending a set of ls6 heads 1 have to them for stage i job but i may wait and see if i should save up a lilttle more and buy the stage 2. hopefully some guys who have these heads will give you some track times to help you decide
They are great heads. You may also want to search Ls1tech as TEA had much more discussion over there. Can't go wrong with a Futral cam and the TEA heads. I had a set on my car.
TEA has also been working with TFS on their new heads.
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
TEA are KILLER heads and ask for BRIAN TOOLEY over there as he is the main head porter and previous owner. Bought there stage II LS6 heads several months ago for m forged blower motor and the heads look great and flow INCREDIBLE air (almost identical to how the Trick Flow 215s flow)!
You have to pay a core charge for their heads or give them your heads and you for a core you can pick up really cheap GM heads for your core that TEA will accept from PATRIOT PERFORMANCE. I did this and got GM casted LS5 heads from Patriot for around $439 shipped to TEA as my core charge! Brian TOOLEY turned me on to that trick at TEA and great way to go as its cheaper than there core charge (unless you have LS heads to give them for your core)!
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by z28flash
Where should I go if interested in TEA heads? I've heard of them on the forum, but haven't found a link for info/purchase.
Thanks!
Be carefull with the heads. My motor blew up because of a set of their heads
