Okay guys,
Thinking of either doing a Cam or adding a 100 hp wet shot.
I welcome your personal opinion on the subject.
I know I can get more power out of the nitrous kit, but the cam would have better power for everyday use.
What do you think horse power wise I could get out of a Cartek 2x or 3x cam only. Would I have to make other modifications to the car (i.e. springs... etc.)? Oh and the car is a daily driver at the moment.
Untuned the car put down 383 RWHP and 370 RWTQ
Car is a 2003 Z06
Mods:
Halltech
LG street long tubes with x pipe (no cats)
spray is fun but too much of a hassel. Every time we were scrambling to get the bottle filled. We did put the cam in first though..so we just took all the spray stuff off and now run 12.88 NA on our Silverado.
Go with the cam in my opinion. Check this 4200 lb heavy load out, then and just think what your 3100 lb Z will do (private old strip of course, not on the highway)!!!
St. Jude Donor '10
def cam... i just did a hpe S cam kit and my car is awsome, i love it.. the power is always there and the car sounds insane! plus i put down 448rwhp and thats alot for just a cam kit! if u want to hear my car go to youtube and type in cammed ebz. its just a quick vid i put up so my buddy at college could see it...oh and i would try to look at other cams than cartek, just heard there all about the $ and not about HP...
Do both! Ok well if you cant the cam would probablly be a good start, I have a ADR4 cam from Advanced Dyno in my car and love it! Makes great power and sounds great. Check them out...
i have the cartek stage three cam and i like it alot.they might not be the cheapest place around,but they do good work and seem to be one of the fastest at the drag strip.their 475hp cars seem to out run alot of 500 plus hp vettes.hmm.....
What cam does eveyone recommend (with stock LS6 heads)? I would like to get as close to 440 RWHP as possible. The car is a daily driver, but I only drive about 6 miles to work and then on the weekends. I would like a nice Lobe (anti stealth).
Oh and it would see Track duty a couple times a month (1/4 mile).
Thanks again for all the help.
Geez, you're going to need a pretty huge cam to even get close to 440rwhp. You might be better off getting some nice heads and a less aggressive cam to hit that number. Also, a cam-only set-up for 440rwhp will probably be very soft down low and not all that fun to drive. You will also probably need a FAST 90 and other supporting stuff that adds up $$ quickly...
For a daily driver you can't go wrong with the 2X cam. I love how it drives on the street.
Did you install your cam first or doheads and cam at the same time. Just curious what RWHP/ trap speed one could get with this cam. (car would be C5 Z06 with headers and CAI) Any guesses?
