Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
will a different intake help performance
Old Apr 8, 2008 | 09:23 PM
02402ramair's Avatar
02402ramair
Default will a different intake help performance
I have been looking into a cold air intake for my C5. The current intake has a 90 degree bend right before the MAF sensor and I have been told that the 90 causes bad MAF readings. My current setup just sits on the radiator shroud witch seems like it wouldn't get much clean good air. I can not run the Vararam due to the dedicated fuel system I have. I have looked at the breathless performance ram induction witch looks like it will clear the dedicated fuel tank.
Do you guys think I will benefit from a better intake system?
What system would be best?
Here is a picture of my setup
here is the vortex ram induction
http://www.breathlessperformance.com/products/218.asp
Old Apr 8, 2008 | 09:40 PM
Ryan L's Avatar
Ryan L
Not to mention the pressure loss in a 90 degree bend is equal to 5' of straight duct length. Just go for an open element filter, like you linked above. The Blackwing and Stinger are other options too.
Old Apr 9, 2008 | 08:03 AM
02402ramair
anyone else have an opinion
Old Apr 9, 2008 | 08:19 AM
02402ramair
Both blackwing and stinger are very similar to what I have with the exception of the 90 in the pipe. I don't think I would benefit much from either one of those.
I guess my question is= Will a ram air intake system out perform my current intake system?
Witch ram air intake system is best?
Vortex
Vararam
Honker
am I missing any more?
Thanks for any input on this guys.
Old Apr 9, 2008 | 08:52 AM
yankeevetteconvert's Avatar
yankeevetteconvert
Vortex
Vararam
Honker
I am using the Trap intake with the tunnel port (license plate screen).Works great and is a true cold air intake.
Old Apr 9, 2008 | 10:34 AM
ALVETTE00's Avatar
ALVETTE00
Where are people getting these fancy aftermarket fuel rails!!!
Old Apr 9, 2008 | 02:03 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Vortex
Vararam
Honker
Halltech TRAP If they still make them,.it is my favorite.
Old Apr 9, 2008 | 02:08 PM
02402ramair
FAST
Old Apr 9, 2008 | 02:56 PM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Vortex
Vararam
Honker
To will a different intake help performance
