Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
1998 How to launch
Old Apr 19, 2008 | 10:49 PM
toupstrio's Avatar
toupstrio
Default 1998 How to launch
Im thinking of running at the local track for test and tune. My question s do I turn traction control off? Or leave it on?
98 6 speed no mods. Also what rpm do I kaunch for best results?
Shift speeds etc?
Old Apr 20, 2008 | 10:26 AM
corvettejoe98's Avatar
corvettejoe98
turn it off!!!
Old Apr 23, 2008 | 10:46 AM
Hysteria's Avatar
Hysteria
Turn off your traction control.
Launching the car...Bring the RPM's up to about 2500 RPM and then when you're ready to launch, release the clutch slowly (Slip the clutch) to get the car rolling and then lay into the throttle.
Don't dump the clutch, because you'll only spin the tires.
If the car bogs on the start, try bringing the RPM's up a little higher and then trying the same thing. Your main goal is to have the car just chirping the tires a little bit on the launch. With some Mickey Thompson Drag Radials, you'll be able to launch the car a little harder and at a higher RPM.
As far as shift points, this is going to Depend on how much power your making and your peak power RPM, this will help you decide your shift points.
For example, if your car is making peak power at 5800 RPM, you want to shift 150-200 RPM past 5800, so that the Revs will be almost back up to the peak and you'll stay in your powerband. If you shift too early or right at the peak RPM, the Rev's will drop a little lower on in the powerband making the motor take longer to build back up to the peak RPM, resulting in slower ET's.
Good Luck and let us know how you do.
Old Apr 30, 2008 | 12:49 PM
toupstrio's Avatar
toupstrio
Thanks for the details
To 1998 How to launch
