Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Her are my dyno numbers
Old May 3, 2008 | 10:41 AM
it's a vette's Avatar
it's a vette
Default Her are my dyno numbers
My car is an 00' a4 witha vararam, ported throttle body, ls6 intake, xpipe and corsas. The base line was done with my hand held preditor. This was done on a dyno jet using hp software. I also add 3.42 gears an a 2600 vig. stall.
Old May 3, 2008 | 10:56 AM
nickolbag's Avatar
nickolbag
Well the TQ is messed up, obviously. But the HP seems pretty good. Having fun with the new power?
Old May 3, 2008 | 11:08 AM
it's a vette
Default how is the torque mess up just wondering
I also went from 2.73 to a 3.42 gear and I add a 2600 vig stall converter and that's with the stock manifolds so that could play a factor in the torque numbers.
Old May 3, 2008 | 12:18 PM
nickolbag's Avatar
nickolbag
I "think" (not 100% sure) that if the converter isn't locked it will give you a spike in TQ. So I'm assuming they didn't lock your converter and it caused that initial spike in TQ which isn't technically a correct number. I'm not 100% sure though but I'm sure someone will confirm or correct me.
Old May 3, 2008 | 01:23 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Thats what i thought too. Torque spiked because of the converter. Get it to the track and get the numbers that count!
Old May 3, 2008 | 02:10 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
now add some long tube headers and let her breath
Old May 3, 2008 | 07:17 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It seems that the TQ converter was not in the locked mode for the dyno tune at first, contrary to what I thought earlier.
Ask the tunerr to look up the tune and confirm, but have fun with the new found power and regardless it's not bad for a pretty much stock C5
It looks like your stock exhaust manifolds are making a lot of Torque too!
I see what you were saying as to the spike, it almost looks like the graph is inverted or needs to be flipped.
Yes I also agree with the above put a set of HEADERS on it to let it actually breathe!
Not bad for a pretty much stock C5
Thanks,Matt
To Her are my dyno numbers
