Need for Speed under 11.5 - Help!
Here are my questions and set-up:
Originally my goal when modding the car was to have the car run in the 11's. I have accomplished that and have been running in the 11.7's and have now got the itch to run in the lower 11's so that I could possibly run in the 11.5 index at some point.
Currently I have:
04 coupe tuned with 233/239 cam, underpulley, headers w/cats, corsa's, 3600 T/C and 3:73 gears running ET streets radials on wagon wheels and small 205's up front.
It's obvious I need heads, intake, T/B, injectors or a combination of them, but my question is what is the best bang for the buck to reach my goal?
Best runs (65 temp): (85 temp)
R/T - .102 - .132
60' - 1.650 - 1.671
330' - 4.837 - 4.887
1/8 - 7.50 - 7.551
MPH - 92.00 - 91.53
1000 - 9.807 - 9.868
1/4 - 11.746 - 11.817
MPH - 116.56 - 115.92
Elevation at the track is 450'. The first run I posted was a corrected elevation of 975 and the second run was 1865.
I believe I'm also not stalling enough at the line. I'm only stalling to 1700 or so and with this converter I should be able to hold at least 2500 rpms. How much of a difference would that make in my 60's?
Thanks for any input.
I am a fan of the 11.5 index, but I would probably have to switch over to a rollbar for my vert to be competitive.
Heads are going to be what gets you over the top, it needs to breath. Not sure that's the cheapest but it will do the most for you w/ that cam.
