i looked at both and it didnt give specific hp ratings. i know the same setup could yield different power results. the reason being is i am wanting to get deep into the 11's probably around an 11.5 is my goal but i am not sure exactly what it will take to get there.
i know when i had the ///m i was putting down around 550 to the wheels and ran an 11.1 @129 but i know they are a couple hundred pounds heavier than the frc's
Head and cam package or go F/I =) and you shouldn't have to worry about your 1/4 mile time unless you are on a budget then you might want to state that. Best shot is to contact a local performance shop and see what they can put together for your car and take in consideration pre-existing mods.
well i am planning on doing an lg motorsport g5x3 cam with lg longtube pros with a set of 205 heads, a 4:10 gear, cut outs and some DR's that might narrow it down a little, i just have no clue where those mods would get me
