Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Help decipher some times
Old Oct 29, 2008 | 11:39 AM
exploder's Avatar
exploder
Default Help decipher some times
I went to the track the other day and ran a few passes starting with a 10.6 at 136 then 10.4 at 137 then 10.2 at 136. The two last passes are what I really want some input on. How much mph are you supposed to pick up on the back half?
60' 1.53
1/8 6.5
mph 109
1/4 10.02
mph 142
60' 1.53
1/8 6.4
mph 111
1/4 9.96
mph 137
Old Oct 29, 2008 | 01:47 PM
simpleman68's Avatar
simpleman68
60' 1.53
1/8 6.5
mph 109
1/4 10.02
mph 142
60' 1.53
1/8 6.4
mph 111
1/4 9.96
mph 137
You are really making some power there.
The difference in trap speed may correspond with a quicker ET. I have heard that often at the track. Some of my "quicker" runs were not as "fast" as the slower runs.
It also helps a lot to have some trackside support to analyze the runs after each pass.
Scott
Scott
Old Oct 29, 2008 | 03:05 PM
Blu's Avatar
Blu
Is the car a Manual or Automatic?
Old Oct 29, 2008 | 04:28 PM
exploder's Avatar
exploder
automatic....but I changed it from a manual. From the log files it shows I am letting off the gas to about 80% after the 1/8th when it gets kinda squirly uptop.
Old Oct 29, 2008 | 05:00 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
What rpm are you shifting at?
Plus without making a few 100% throttle passes to go off of, it's hard to get good data.
Old Oct 29, 2008 | 07:16 PM
exploder's Avatar
exploder
shifting the car at around 6300 with the auto. i used to shift around 6500 with the 6 speed. do you think I should up the shift points some?
Old Oct 30, 2008 | 08:24 AM
Blu's Avatar
Blu
Yes definitely! I don't even know your setup but the higher shifts points will really help out if you are running a centrifugal blower which is my guess from you traps.
To Help decipher some times
