Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
WHAT WILL I RUN adding headers and AFRs
Old Oct 29, 2008 | 11:28 PM
holley505's Avatar
holley505
Default WHAT WILL I RUN adding headers and AFRs
My best time so far 12.2@ 111.8
I typically run about 12.4 @110
Currently running 01 346 and 03 6.0 heads milled to 65cc
i have a Comp cam 224/224 581/581
3000 stall TH350 with 3.36 gear in 3170 lbs C3 vette
Running a Carb (680 Holley DP) and Performer RPM intake
NOW... just got a set of LONG TUBE HEADERS (coated) and AFR 205 heads milled to 62 cc, CNC ported and polished, with the best springs.
Hoping to pick up 60 horse and about .6th-.7th and 5-6 MPH?
Does that sound about right?? new best 11.6-11.5 @116-117?
Thinking I might need to go with 3500 stall....and the Victor JR single plane intake may give me .2-.3th more??
Old Oct 31, 2008 | 07:42 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
With good traction, that stall, a good launch and that weight, I would think you should be able to pull off some high 10's. Wouldn't that be nice!!
Old Oct 31, 2008 | 12:01 PM
holley505's Avatar
holley505
WOW !!! I love the way you Think...
I doubt that...
but it would be SWEEEEEET !!!!
To WHAT WILL I RUN adding headers and AFRs
