How many Tenths can I expect from a Catback?
Received 1,584 Likes
My car has run 13.1 @ 106/105mph all 4 passes a couple weeks ago. It feels as though the exhaust is choked up on the top end. I only have a Blackwing and cold air screens. Otherwise it's bone stock.
How many tenths can I expect from a good catback system such as a Borla? .2? .3? I'd like the car to run at least 12.8.. Thanks!
Headers,X-pipe,and the catbacks should be about a 0.3 improvment on a stock motor.With the improved exhaust flow all your additional mods will show a much greater increase in HP/TQ.
A catback will give you a nice sound, no performance increase. Do you have an auto or 6 speed? With a 6 speed i'd slap some sticky tires on it and go to town. With an auto do a stall and some sticky tires. In either case you'll be running better than your 12.8 goal with just a little bit of practice.
Edit: For the record I went 12.7 my second time out with nothing but BFG drag radials and a tune(stock intake, exhaust, even the factory air filter!)
Thanks for all of the replies. Makes sense. Looks like I need to do the entire exhaust and a tune.
Atco, that improved to 12.640 with the same setup(tune, sticky tires only)
torque converter (2800) and sticky tires. I use the 17" MT DR's.
Just my 2 cents.
I guess a tune makes a considerable difference. Any recommendations on who to go to? Anyone send their PCM out? Or is it better to have it done on-site.. ?
Pretty much right.
If you have the funds.......go with a good quality set of headders and you might want to ditch the blackwing and go with a Vararam which IMHO is a better overall cold air intake, then have it tuned. Should be good for a noticable increase.
Not sure where Dover is in NJ, but if I lived in NJ, I would go to ECS for a tune. I am lucky enough to have The Vette Doctors nearby to handle all of my work. I would still invest in the headers.
I would recommend TTP in north jersey: http://www.ttperformance.net/
Matt did my tune and it's 100% spot-on
What's everyone's take on cutouts? Maybe cutouts in the stock exhaust before the mufflers? (Not sure if I want to go the whole headers route yet. Maybe next spring or summer.)
Again, good if you want some noise, but won't give you any HP increase. I would recommend just saving up for the catback of your choice instead of doing the exhaust twice. Personally I have the GHL bullets and they are perfect. Granted, they're a bit expensive compared to other exhausts out there but I think the price is justified for the system.
If you are looking for a tune there is also Cartek in Garwood. I have been using them for years. Julio is the mand when if comes to tuning LS engines.
Curious, what was your 60' at Island? I bet not good. I was there a few times this fall and the track prep is typically a lot better at Atco or E-town. Hit Atco this fall and I bet you see a nice improvement in ET. The Atco mod is definitly a lot better than a catback
Do you know how much Cartek charges for a tune? What program do they use? (thanks..)
