Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
need advice on next mod.
Old Jan 10, 2009 | 04:51 PM
a/c man's Avatar
a/c man
Default need advice on next mod.
i have 04 c5 auto 3.43s stock ex with ti cat. 8 lbs boost procharged with meath kit msd boost pump (motor is stock) it made 501rwhp i ran it at the track 11.50 on street tires i thought it could be better!10.90 is what i would love to see. it is a daily driver so i dont want to get to crazy with it. let me know if you have any advise or exp that my help me. scott
Old Jan 10, 2009 | 10:53 PM
Tsab's Avatar
Tsab
Go get a CCW drag-pack with ET streets and skinnys. Or a good pair of Drag Radials. Try tires first before going any further with mods.
Old Jan 11, 2009 | 12:58 PM
j0n's Avatar
j0n
I've gone 11s with only 336rwhp by focusing more on the first half of the track.
Old Jan 11, 2009 | 01:13 PM
a/c man's Avatar
a/c man
thanks ill try to hook better first! then a stall 2800 what do you think? to small on my daily driver
Old Jan 11, 2009 | 04:37 PM
paint it black vette's Avatar
with your power bigger stall. but then again i want to go a little crazy. dr's at least a must.
Old Jan 13, 2009 | 08:53 PM
a/c man's Avatar
a/c man
hey can anyone help me? i put some hoosier 275/40/17 drag rads d.o.t.with 25lbs air, but not for the street.and my car spins worse than before with my 285/40/18 gy super cars whats up! thanks scott
Old Jan 13, 2009 | 09:16 PM
GARY2004Z06's Avatar
GARY2004Z06
I would recommend doing a very large burnout and dropping the tire pressure 2 pounds at a time. We generally run from 17 to 22 psi in our cars. Granted I do not have your HP, but my Hoosiers hook much better than my 295x35x18 SC tires. My best on SC tires was 1.75 bonestock while I have cut 1.46 with my current setup on the Hoosiers. How is the track prep?
Old Jan 13, 2009 | 11:16 PM
a/c man's Avatar
a/c man
i did 1.90 on my sc gy streets the track prep is only good when they have a good event i tried the hoosers on the black top today! no major burnouts scared of the cops it just got way to loose i felt like i wasted my $$ on 17 rims and tires but tommorrow 20 lbs air stage 5 burnout!! then ill know what it can do! thanks sounds like thats what they need to hook!
Old Jan 14, 2009 | 06:59 AM
j0n's Avatar
j0n
Yea those tires need some heat in em to get sticky, I would do a burnout just big enough to get a little smoke out of em... that should be plenty to hook up really well.
To need advice on next mod.
