Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Cam question
Old Jan 14, 2009 | 08:00 PM
coanan's Avatar
coanan
Default Cam question
I have stock LS6 243s, Cometic .040, kooks with hi-flow cats 3" to the back, LS6 intake, with a TSP228R 114LSA 405RWHP 373RWTQ.
How much will I gain with a TSP V2 233/239 on 112LSA .598 and .603 lift?
Old Jan 14, 2009 | 09:40 PM
ZZOOM06's Avatar
ZZOOM06
Just a guesstimate, you should pick up 20-25 HP/TQ. Throw a nice set of ported 243's on and bring your compression up to 11.5 or so and you might get 20/25 more!
Jimbo
Old Jan 15, 2009 | 07:24 AM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
I have a ported FAST intake with milled and ported 243's from Cartek with a 228-232 582/598 lift cam and I made 453 and 400. Im thinking of swapping the heads to a nice set of milled and ported Trickflows for that extra 30 rwhp im missing! LOL
Old Jan 17, 2009 | 11:42 PM
coanan's Avatar
coanan
What would 1.8 rockers do for me?
Old Jan 18, 2009 | 12:51 PM
paint it black vette's Avatar
good idea im already going there with the trickies and a custom grind also think about the 1 7/8 header change
Old Jan 18, 2009 | 01:21 PM
98vettedave's Avatar
98vettedave
What is your present lift with the 228R cam running with 1.7 rockers.The 1.8 ratio rockers will increase the valve lift by approximately .032 and dule springs should be used.You also need to take into consideration the ramp speeds of the cam to be used.Quicker ramp speeds will make the valve train less stable at high rpm's with 1.8 rockers...Comp has a grind of cams that are engineered for higher ratio rockers. If your cam lobes are not overly aggressive and the 1.8 ratio rockers were used then you could possibly see a increase of approximately 8 HP.
Old Jan 18, 2009 | 03:01 PM
coanan's Avatar
coanan
there're 588 lift with XE-R lobes. Currently using Comp 918s, but have a set of Comp 921s that I could use.
To Cam question
