Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
New Dyno results but skeptical....
Old Feb 11, 2009 | 10:18 PM
gsx750r93's Avatar
gsx750r93
Default New Dyno results but skeptical....
[IMG][/IMG]
Seems pretty high to me.
This is also a 4th gear pull and we did about 5 or 6 pulls and basically the same everytime. We also did some 3rd gear pulls we were getting readings of 442ish whp.
My mods are
-X-Pipe
-lg long tube headers
-under drive pulley,
-dyno tuned
-varamram intake
-ls6 intake mani
-Thunder racing complete spring set
-TR230/236 cam 112 lobe separation
-b&m shifter
-12 pound flywheel
-spec clutch.
Old Feb 11, 2009 | 10:54 PM
Kurtomac's Avatar
Kurtomac
that dyno needs to lay off the crack pipe
Old Feb 11, 2009 | 10:56 PM
gsx750r93's Avatar
gsx750r93
Ok i just talked to my buddy that works at that shop and i was told that it is dyno jet numbers or something.. He just told be it is %17 corrected
Old Feb 11, 2009 | 11:00 PM
gsx750r93's Avatar
gsx750r93
Im confused looking at your mod list... 469 RWHP 418 RWTQ ???
Im prob being an idiot and missing something here.lol
Old Feb 12, 2009 | 05:52 AM
ZO6DRIVER's Avatar
ZO6DRIVER
great tq. curve regardless. 17% damm thats alot...
you got it tuned on a true REAL WORLD DYNO anyway. that's what matters. ENJOY!!!
Old Feb 12, 2009 | 07:41 AM
Blu's Avatar
Blu
17% corrected, thats funny. The dial your own HP strikes again. According to this shop you now easily hold the highest RWTQ of any NA 346 stock bottom end with a cam only C5.
Get on a dynojet if you want actual dynojet numbers. You would be lucky to make 420rwhp 390rwtq with that setup on stock heads.
Old Feb 12, 2009 | 07:48 AM
vsocks1's Avatar
vsocks1
From what I was told the Dyno Dynamics can display numbers as is or in "Dynojet Mode". When I had my mostly stock Z06 (Headers,halltech Venom,Tune) dynoed at the track I got 423 rwhp in that mode! In the more stingy mode I got 366 rwhp.
Hope that helps!
Old Feb 12, 2009 | 08:22 AM
pit-man's Avatar
pit-man
I know my cam isn't too radical and my compression is only 11:0, but dang !! I am only getting 480 rwhp with my 383 Stroker motor
Pitt
Old Feb 12, 2009 | 08:28 AM
Blu's Avatar
Blu
Pitt
get on a DD corrected to 1.17 and you will make 540rwhp
I don't like or agree with these "corrected to read like dynojet" numbers but the most accurate I have seen for a dyno dynamics is like 10-11% corrected. A local shop used 1.13 and it was pretty inflated over what local dynojets were reading. Also DD torque numbers are usually pretty close to matching dynojets without the inflated CF.
Check this out.
http://www.ls1tech.com/forums/dynamo...omparison.html
Old Feb 12, 2009 | 09:02 AM
Kurtomac's Avatar
Kurtomac
can you repeat the question...
i have heads, cam, fast
Old Feb 12, 2009 | 09:04 AM
Kurtomac's Avatar
Kurtomac
Pitt
PITT FAILS AT LIFE
KIK IN TEH BALZ
Old Feb 12, 2009 | 09:39 AM
pit-man's Avatar
pit-man
He thinks your kind of short a little...you know, just like all the women you have met thought...
Pitt
Old Feb 12, 2009 | 10:03 AM
Kurtomac's Avatar
Kurtomac
hey man 3 twice is 6 right?
Old Feb 12, 2009 | 10:26 AM
Quick Shot xMLx's Avatar
Quick Shot xMLx
Dyno Dynamics usually read lower than all other dynos if not messed with. On my old Mustang I made 343 whp when everyone with the same exact mods were putting down like 370 whp on dyno jets. They have a 'shootout' mode than uses some correction factor to display 'dynojet' numbers. It's usually pretty spot on but in this case their dyno is smoking some good stuff.
Old Feb 12, 2009 | 10:52 AM
gsx750r93's Avatar
gsx750r93
Nope i have 470 whp and im sticking to it..haha just kidding.. Glad i only spent 50 bucks on it.He just had a c5 z06 with the same dyno setup seeing as how he doesnt change it dyno i believe around 380ish whp.
Im so confused on this whole dyno thing..Dynos always seem to read way different numbers..At least the ones where i live for the most part.Im assuming its because of the fact that some of these shops dont want to hurt the customers feelings by giving them low numbers.
To New Dyno results but skeptical....
