dude rule out other **** before you do that....clutch and headers for one
maybe pull the inspection cover for the clutch and take a peak
smoke 10 cigarettes at ones and blow lots of smoke into your engine bay see if theres a leak on your headers somewhere....im in bottom end ****ed denial sorry
The headers are fine. Checked them at the track and today. I can not see how it can be the clutch. The noise is loudest right under the valve covers. There is no noise coming from the clutch area at all. It still may not be bottom end. Maybe its a lifter problem.
Originally Posted by sixspdvet
Nick, Before you do all that, why not drain the oil and see if you see any metal in it. Not to scare you but!
Goats? Nah that's for you Northern Boys..
Ernie
Metal in the oil would hint at what? Bearings? Maybe tomorrow if its not snowing I'll drain the oil and see what I see.
Any chance of this issue/noise being flywheel related?
The noise is at its strongest under the valve cover. There really isn't much noise at all coming from the clutch area. The clutch felt completely normal during the burnout.
Hmm, could be something as simple as a rocker lightly tapping the valve/rocker cover?
Doesn't make sense that it would just suddenly start doing that with nothing else being bent or broken/no other symptons but hey, anything is possible.
If so, that would also likely mean that once you put it all back together and tighten it all back down that the noise will be gone too.
Hell after the compression test give that a shot for ****s and giggles..... can't hurt much more IMO. I forget what do the roller rockers get torqued down to is it 35ftlbs?
hell after the compression test give that a shot for ****s and giggles..... Can't hurt much more imo. I forget what do the roller rockers get torqued down to is it 35ftlbs?
After I tightened everythig back down I did. It idles smooth at 1k rpms. I had my ear to the motor trying to listen to where the noise was coming from. After everything looking fine I though I'd hear something from somewhere else. The noise is clearly loudest under the valve covers. It sounds like a metal object tapping another metal object.
Next chance I get I'll drain the oil and see if theres any metal in there.
After that I'm guessing the heads have to come off next to check the lifters. Now when I pull the heads should I drain all the coolant beforehand? I hear pulling hte heads is easier if you remove the water pump so I guess I have to drain it all. Maybe I can get an electric water pump while I'm at it.
I hear if you don't get as much coolant out as you can...it will make a real mess when you pull the heads! Haven't done mine yet but that is what I have read..Good luck!
nick try pulling the valve covers again....and have someone turn the motor over with your coil packs unplugged....watch all rockers move....try to see if they all move evenly...that might help identify if you have a ailing lifter and wayyyy easier than pullin the heads.....then drain your oil that you have 100 miles on and check that...make sure you have a magnet handy...stick it in the oil stream as its draining see what you find
I guess when I do the compression test I can watch the rockers too.
Literally 100 miles. Should be easy to spot some metal in that.
As I posted in the clutch has been installed thread - "lifter" and I am still leaning in that direction.Based on all the visual inspection of the up top valve train (springs,rockers,and push rods)that appears to be the only up top components left to be checked.Of course if the leak down (compression)check proves to be suspect,then obviously that means the motor needs a rebuild....hopefully that is not the case.
Nick just get the Ham wallet out and slap it down on the card. LSX 440 installed with heads,cam and put your intake on. Tuner in and 9's all day Come on everyones doing it!
Well I hope you are right with the lifter. With what I heard under the valve covers I just can't see how it could be coming from the bottom end.
By "the card" do you mean your card? Just PM me the numbers and I'll place my order online right now.
Yes, all the coolant out before pulling the heads.
My bet is a lifter...but its anyones guess at this point!
I hope you and Dave are right. This definitely isn't a good time to have to buy a new bottom end. But then again.....I wouldn't mind learning how to pull a motor too.
I'd put money on it being a lifter. We have had a few LS based motors in the dealership here recently (I'm a GM tech) with a sound just like you're describing and every time it turned out to be a bad lifter except once it was a broken rocker. I know how you feel, we couldn't decide if we should pull the heads or pull the trans and look for a cracked flexplate. If it is a shot lifter you will probably need a cam as well. Might just be an opportunity to go bigger!
