Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
ls1 cam swap
Old Mar 1, 2009 | 10:03 AM
c5vetteman99's Avatar
c5vetteman99
Default ls1 cam swap
hey guys, i have a 99 vette with lg streets with cats, corsa pace car, and a hurricane intake. i want to install a cam that has a nice chop at idle and good hp numbers. i'm not sure what kind of cam i should buy and what supporting mods. i will need. i would appreciate your input.
tyler
Old Mar 2, 2009 | 11:17 AM
slothy's Avatar
slothy
texas speeds - ms4 if you want a good choppy idle
as for supporting the cam - hardened push rods, dual valve springs, oil pump and good tune
Old Mar 2, 2009 | 01:31 PM
j0n's Avatar
j0n
I would consider the Polluter if I were in your shoes.
Old Mar 2, 2009 | 04:17 PM
MG RED 99's Avatar
MG RED 99
Best advice I can give is if you plan on having it installed by a performance shop, talk to them since they will most likely be doing the custom tune as well. They should be able to make any cam wild to mild run well, or they probably wouldn't recommend it. My cam is pretty mild by todays standards, which is a comp grind 220/220 .581 112LSA. Very easy to live with on the street, great lopey sound and good power increase. Never had a baseline tune, but dynoed after install at 348RWHP/358RWTQ, with standard bolt on stuff ie; intake, exhaust, tune. This is also on a 99 (LS1 intake manifold) with 6 speed.
Good luck
Old Mar 14, 2009 | 12:50 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
tyler
Here's my setup which produced 367RWHP and 365RWTQ, with a Z06 cam. I'm running a 2000 coupe.
Good luck with your project.
Stock Bottom,
A4 tranny
LS6 Heads, Gen III,
comp. cam(921) dual springs/titanium retainers,
7.400chm pro pushrods/
LS6 Intake/
2004-Z06Cam,
LS2 Timing chain,
Ported LS6 oil pump,
25%UD Pulley,
Black Wing
LG Streets, X-Pipe, H/F Cats, Z06-TI‘s,
3:15gears,
30lbSVO Fuel Injectors,
Old Mar 16, 2009 | 12:20 AM
slick 01's Avatar
slick 01
7th Gear
why no supercharger!
Old Mar 16, 2009 | 12:33 AM
C5XTASY's Avatar
C5XTASY
Old Mar 16, 2009 | 08:33 AM
Kurtomac's Avatar
Kurtomac
i might be selling my cam soon 236 238 601 605 113+2 comp grind
made 469rwhp with a set of heads and tuning made 417rwtq.....350rwtq at 2800rpm
Old Mar 16, 2009 | 08:39 AM
c5vetteman99
dont have the money for that
Old Mar 16, 2009 | 01:35 PM
nickolbag's Avatar
nickolbag
You gotta love a cam called the Polluter.
To ls1 cam swap
