Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
99 frc. H/c/i/e
Old Mar 11, 2009 | 06:34 PM
99FRC Newb's Avatar
99FRC Newb
Default 99 frc. H/c/i/e
just got the baseline dyno numbers from Speed Inc (before tune)
170 RWHP
turns out i had a bad maf. filter was kinda dirty too. 16:1 Air/fuel ratio!
dyno run was from 2500-3200
FIND ME ANOTHER CAR WITH 170 RWHP TO RACE!!!
New maf is on the way. filter is clean (took a couple tries! it was BAD)
i'll get you guys some real numbers when the car isn't insanely lean!
FINAL NUMBERS
441/400
dyno numbers on spray coming later this week
Old Mar 12, 2009 | 10:33 AM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Good numbers. Are those from LS6 heads? Tell us the setup.
Old Mar 12, 2009 | 11:57 AM
allngn_c5's Avatar
allngn_c5
99 FRC's have ls1 heads.
Old Mar 12, 2009 | 12:39 PM
nickolbag's Avatar
nickolbag
Yea but the OP doesn't have stock heads.
Old Mar 12, 2009 | 01:33 PM
allngn_c5's Avatar
allngn_c5
I know. Just stating that 99 frc's have ls1 heads from the factory, not ls6 heads.
What heads are on this 99 FRC ?? How about a little more info on the setup ??
Old Mar 12, 2009 | 01:34 PM
allngn_c5's Avatar
allngn_c5
I made a sig for this forum, and you can't display it, why not ??
Old Mar 12, 2009 | 03:27 PM
99FRC Newb's Avatar
99FRC Newb
SI5 cam
Patriot Stage 2 LS6 heads
F.A.S.T. 92mm intake
LS2 ported Throttle Body (90mm)
Blackwing Intake
Kooks 1 7/8 Long Tubes
Kooks Off Road X-Pipe
Powerbond Underdrive pulley
C6Z Shifter
LS7 Clutch w/ LS2 flywheel
DTE Diff Brace
3.73 gears
LPE Fuel Pump
Fast 36 pound injectors
Dynotune Wet nitrous kit (Fbody kit modified to fit my car)
Speed Inc full dyno tune
dyno freaked out a little, but you guys still get the idea
Old Mar 12, 2009 | 05:36 PM
JDaniel's Avatar
JDaniel
Wow! Are you kidding me. Are you new here or what? This is the "Performance results" forum. Welcome.
Old Mar 12, 2009 | 05:39 PM
JDaniel's Avatar
JDaniel
Originally Posted by 99FRC Newb
SI5 cam
Blackwing Intake
C6Z Shifter
DTE Diff Brace
3.73 gears
LPE Fuel Pump
Nice numbers for that setup. Im going with the ARH 1 7/8's pri and 3" X pipe. I cant wait to see what the differences from the 1 3/4 pri and 2 1/2 Bassani is.
Old Mar 12, 2009 | 05:48 PM
slowzoh's Avatar
slowzoh
800 ft/lbs of TorqueCongrats, thats a hell of a setup
Before somebody comes in to act like a know it all and explain the spike, I am just kidding
Old Mar 12, 2009 | 10:05 PM
99FRC Newb's Avatar
99FRC Newb
its a diesel
To 99 frc. H/c/i/e
