Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Shift Light (LED)??
Old Apr 18, 2009 | 09:47 PM
bojangles5169's Avatar
bojangles5169
Default Shift Light (LED)??
OK - Maybe y'all don't need one but I do. Things start happening pretty quick when you drop the hammer - specially in the first couple of gears and I find myself not paying attention to the tach like I should. There's a lot of Z's out there with more HP than mine but I'm pushing the limit on non forged innards and a stock aspirated LS6. I did a forum search b4 I did this post but found nothing telling me I might be somewhat retarded?? Is there anyone out there that frequently goes past the red line or someone who has done a sano install of a shift light? I'd sure like some info on brands that work and sano install locations in a '02 Z06.
Many Thanks in advance from an over the hill hot rodder
Old Apr 18, 2009 | 10:24 PM
j0n's Avatar
j0n
I used to run the Raptor shift light on my old Trans Am. Whenever I get around to it I plan on installing it in my Corvette. I'm going to mount mine on the a-pillar up high.
Old Apr 19, 2009 | 12:06 AM
sixspdvet's Avatar
sixspdvet
I used a Auto Meter.. worked good.
Old Apr 19, 2009 | 02:23 PM
bojangles5169
Thanks for the responses
Yeah - I thought the A-pillar up high might be the most noticeable. The Zs are pretty well guaged out as you know - I'm not planning to run boost or anything else and most A-pillar replacements for guages have a 3 guage setup. Anyone know of a source offering a 1 guage pod?
Old Apr 19, 2009 | 02:32 PM
j0n's Avatar
j0n
You won't need a guage pod for the raptor, just attach it to your stock a-pillar. It's a very small diameter so it would look silly in a gauge pod.
Old Apr 19, 2009 | 02:51 PM
98vettedave's Avatar
98vettedave
I have the small Auto Meter shift light mounted on the A pillar.It is attached just a little lower than the fuel pressure gauge pod and is pointed right at my eye level.
Old Apr 19, 2009 | 06:08 PM
FourG63 97GST's Avatar
FourG63 97GST
my skip shift light now my shift light, works for me
Old Apr 19, 2009 | 06:45 PM
Wickd1's Avatar
Wickd1
So i have a raptor shift light now. its mounted to the piece of trim right above the rear view mirror, but it still isnt bright enough for me, Will the Auto meter shift light install (wiring) just like my raptor light?
thanks
Old Apr 19, 2009 | 07:44 PM
bojangles5169
That was my concern
thanks
I need a light that will get my attention. I was looking at the Auto Meter light - looks like they offer both the smaller LED version like the Raptor or the larger light that would fit in an A pillar pod. I'm going to check it out. AND - what about the wiring connections - I've never been one that likes to splice in to stock wiring harnesses - sometimes a recipe for disaster. I converted my Bose sound system to JL complete with amps and mp3 player, kept the stock HU and never cut or spliced a factory wire. Again - any info from someone whose been there - done that will be appreciated. Many thanks!!!
Old Apr 20, 2009 | 08:47 PM
ROJO99's Avatar
ROJO99
I am running the Raptor mounted with two sided tape 3/4 the way up the a pillar.
To Shift Light (LED)??
