Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
MS4 02 z06
Old Apr 25, 2009 | 06:41 PM
z06guy333's Avatar
z06guy333
Default MS4 02 z06
hey guys, just installed my tsp ms4 and brought it to the dyno untuned. the driveability is much better than i ever imagined. the way people talk it up is like its almost impossible to daily drive. i daily drive the car and i love it. il post an update once the car is tuned.
http://www.youtube.com/watch?v=ahEAfp_pqqA
ENJOY!
p.s. don't forget to click HD
UPDATE-------------------------------------------------------
finally got a chance to take it to the track.
my best run of the night was 12.3@120mph w/ 2.1 60ft
the tire filler station was down that night so i was not able to lower the tire pressure on my M/T drag radials. so once i get tuned i will go back to the track and hopefully cut a better 60ft with lower tire pressure.
my next plans are 4.10 gears and possibly nitrous. i know the 4.10 gears will compliment the cam nicely but what about with nitrous? im guessing with 4.10 gears i will be running out of gear at about 130-132 revving out to about 7k. can anyone chime in with any knowledge or suggestions for this setup? thanks!
Old Apr 25, 2009 | 07:04 PM
CraZee ZO6's Avatar
CraZee ZO6
lopes pretty hard!
Get some TFS 215 heads and watch your #s go up bigtime!
Old Apr 25, 2009 | 08:29 PM
z06guy333's Avatar
z06guy333
Originally Posted by CraZee ZO6
lopes pretty hard!
gotta love the lope
i think im going to get it tuned first and have fun with that for awhile before i do heads.
Old Apr 26, 2009 | 12:32 AM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Awesome cam, man!
Who makes the MS4 and whats the specs on it. I would love a bigger cam but I have milled LS6 heads and im not sure if it will work.
Old Apr 26, 2009 | 02:53 PM
slowtealz28's Avatar
slowtealz28
Texas speed makes it, 239/242 .649/.609 I talked to someone who has it and he says it's a dog under 4k rpm. Sounds awesome though.
Old Apr 26, 2009 | 03:27 PM
slothy's Avatar
slothy
I LOVED MINE, lil cam surge under 2k but once it hit around 4k it pulls like a ****. sad i had to let it go for a blower friendly cam.
3.90/4.10 rear compliments that cam perfect
Old Apr 26, 2009 | 03:29 PM
slothy's Avatar
slothy
Originally Posted by JDaniel
Awesome cam, man!
not unless you fly cut
Old Apr 26, 2009 | 06:50 PM
JDaniel's Avatar
JDaniel
Im already flycut. But im not sure what thickness my gaskets are. I was told by LG that I cant run more than a 114 LSA.
Old Apr 26, 2009 | 09:20 PM
tail_lights's Avatar
tail_lights
Originally Posted by z06guy333
gotta love the lope
Old Apr 26, 2009 | 10:21 PM
z06guy333's Avatar
z06guy333
yea it starts to pull nasty at 4k rpm, but its not as bad as most people make it out to be below 4k. going to the track this wed. so il keep you guys posted
Old Apr 26, 2009 | 11:05 PM
tail_lights
Definately keep us posted
Old Apr 27, 2009 | 01:12 AM
94brick's Avatar
94brick
So this cam appears often on the forum and most say its way too big. As far as the "*******" under 4k rpm, with 4:10's in a 6sp I am assuming this set up would be killer? Any comments??
Old Apr 27, 2009 | 01:44 AM
NavyBlueZ's Avatar
NavyBlueZ
Great numbers man! Gotta love that lope. A intake should help free up a lot of hp too, with that huge intake lift.
Looking forward to some track times too.
I've heard it can be a close call even with stock head, so definitely triple check your PTV clearances before you throw a MS4 in.
Old Apr 27, 2009 | 12:00 PM
hector88's Avatar
hector88
a friend of my had this cam on his T/A... car was full bolt on, had ported 243's,4.10 and nitrous... driveability was not all that great, the pull was awsome over 4k.... under 4k the pull was ok but if it bogged a little at the launch the car would feel pretty crappy...the car did have a stock ls1 intake so that didnt help
Old Apr 27, 2009 | 03:16 PM
robz's Avatar
robz
I think it would work well with 4.10's for the street/strip. The gears will pick it right up.
No doubt a 10 second pass with a clutch in good air.
Old Apr 28, 2009 | 01:09 AM
94brick's Avatar
94brick
Thanks robz, I have read alot of your posts and you pull some crazy times out of your set up. I am really leaning on this cam. If some others could chime in on a MS4 + 4.10's it would really help me decide on this combo. Sounds awesome by the way
Old Apr 28, 2009 | 06:02 PM
sami85L98's Avatar
sami85L98
That sound alone sold 100's of MS4 cams, there's black Z06 with black rims on youtube, man awesome sound he got and i was sold the first time i saw that video.
What exhaust setup?
To MS4 02 z06
Old Apr 28, 2009 | 06:34 PM
slothy's Avatar
slothy
What exhaust setup?
that video is what made me want/get a ms4
Old Apr 28, 2009 | 06:43 PM
sami85L98's Avatar
sami85L98
Hey brian, i made a mistake i should have bought ur MS4 cam and other goodies as well. I wanted to swap cams every year for the heck of it.
Old Apr 29, 2009 | 12:44 PM
z06guy333's Avatar
z06guy333
yea i knew i wanted the cam, but then i saw that same video on youtube and it sealed the deal for me
