The last dyno graph I posted I got a lot of flack so I figured this one should realy cause some ****. I was told that the dyno I posted was with nitrous due to it making 600rw.
This is my nitrous pull (300 shot)
I was unable to add the second stage due to having problems out of my Lingenfelter two step/timing box.
WTF!!!!!! Makes me want to throw my ruler out and use your graph to line things up! Thats a straight power curve! Very strong, nicely tuned and should pop a wheelie in the parking lot!
Thanks guys. I installed the Direct port and the plate system this time last year and have just now hit the button. It was a little scary the first 300 hit on the dyno but after that it was like every other pull. I had problems with it dropping cylinders in the high RPMs. It ended up being the Lingenfelter timing controller so I backed it down to a 100 on 1st stage and 100 on the 2nd. That made 750/750 on both kits so I will be running that setup at MMP (PINKS ALL OUT) this weekend. Wish me luck guys. I am going for 9.50s on the 200 shot!
Thanks guys. I installed the Direct port and the plate system this time last year and have just now hit the button. It was a little scary the first 300 hit on the dyno but after that it was like every other pull. I had problems with it dropping cylinders in the high RPMs. It ended up being the timing controller so I backed it down to a 100 on 1st stage and 100 on the 2nd. That made 750/750 on both kits so I will be running that setup at MMP (PINKS ALL OUT) this weekend. Wish me luck guys. I am going for 9.50s on the 200 shot!
Come on didn't you pick up like 30rwhp NA from when you ran the 9.81 with a 100 hit? I say you will go a little quicker than .50's. I would have crapped my pants seeing that wideband right when you engaged the gas.
wonder how long the internals will last before something yields.....
Lets hope it will last a while. Its not like its doing this every day. I have had the fogger and plate on there for close to a year now and this is the first time to spray. When you run 10.2 on motor with a nitrous setup and the southern suck *** DA you don't have much of a need for spray. This is a small hit and just one kit compared to what my intentions are. The 830rw pull was a walk in the park for my little 418. Don't be surprised if you see a 1000rw graph pop up in the near future.
