Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
gearing effect on dyno
Old May 21, 2009 | 06:47 PM
Prop Job's Avatar
Prop Job
Default gearing effect on dyno
What effect do 4:10's and/or a built trans have on dyno numbers?
Old May 21, 2009 | 09:22 PM
Blu's Avatar
Blu
My tuner said he lost 6rwhp from swapping the stock 3.42 rear for his 3.90 rear in his Z06.
Old May 22, 2009 | 09:51 AM
mitchell c's Avatar
mitchell c
Going to a numerically larger gear will give you lower dyno readings. You won't actually lose any HP just your readings will be lower. I have never heard of a built tranny giving lower dyno readings.
Old May 22, 2009 | 11:16 AM
Prop Job's Avatar
Prop Job
That's what I've heard I was just wondering if anyone knew how much lower. I heard about 10 rwhp which sounds about right with 6 lower from 3:90's.
Old May 30, 2009 | 09:48 PM
mitchell c's Avatar
mitchell c
There is no set amount of RWHP you will lose if you go to bigger gears. Different dynos will vary, however figure between 7 & 10 RWHP on the gear swap you mentioned.
To gearing effect on dyno
