Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
224/228 cam
Old May 24, 2009 | 10:50 AM
vet777's Avatar
vet777
Default 224/228 cam
I have been told the comp cam 224/228 581- 115 lsa is a good choice,
but is it streetable without a stall?
thanks.
Old May 24, 2009 | 11:20 AM
rollinred's Avatar
rollinred
i love mind very good street manner with stock stall .
Old May 24, 2009 | 11:59 AM
vet777's Avatar
vet777
thanks for reply, do you have any dyno # & quartermile times with this cam & no stall ?
thanks.
Old May 24, 2009 | 05:58 PM
rollinred's Avatar
rollinred
thanks.
no track times but the dyno numbers are 410 at the wheels
Old May 24, 2009 | 06:27 PM
Wickd1's Avatar
Wickd1
With this cam and 405hp. ive ran a best of 11.89 with the stock stall, going back next weekend to try an improve that #
And with a good tune no stall is needed. also ive seen guys with bigger cams Lay down way smaller #s ,So don't think bigger is always better..heres a clip of mine @ idle
Old May 24, 2009 | 07:43 PM
vet777's Avatar
vet777
thanks, nice #"s I be happy with the time & hp I'll be running similar set up as you , ported 243, tpis long tube's,corsa catback , mti cold air, ls1 edit, except i have 315 rear ratio. 2001 c5.
thanks, i"m sold on the cam, is your lsa 115? 60ft time?
Old May 24, 2009 | 07:52 PM
Wickd1's Avatar
Wickd1
No mine is a 114lsa w/+3 advance, My best 60 is a 1.82 no spin, stock stall though, But 119mph: Good luck with your choice
Old May 24, 2009 | 07:58 PM
vet777's Avatar
vet777
lsa 115? type heads your running to get 410hp?
thanks.
Old May 24, 2009 | 08:46 PM
Wickd1's Avatar
Wickd1
those are some good #s
Old May 24, 2009 | 09:14 PM
rollinred's Avatar
rollinred
thanks.
ported ls6 heads
Old May 24, 2009 | 09:48 PM
paint it black vette's Avatar
thanks.
used to run 224/230 .582/.591 114+2 xer lobes with tsp 2.5 ls-6 heads fast 90/90 1 3/4 lt dyno 438rw 400 ft lbs through an a-4 add 3.73 gears and 3600 stall = 10.97 at 123.66 posted in 1/4 times sticky dec5 2008.
Old May 24, 2009 | 09:54 PM
rollinred's Avatar
rollinred
you my friend have trick flows and that 3600 stall that car will get it with that combo
Old May 24, 2009 | 10:15 PM
yes thats the new setup with custom amr cam installed in feb 2009 and thats when the 224/230 cam and tsp ls-6 heads came out. new setup has gone 10.752 at 126.91 and should have a little more in it
Old May 25, 2009 | 08:59 PM
rollinred's Avatar
rollinred
good luck on your new combo should produce good numbers
To 224/228 cam
