My Dyno #'s seem low?
The first 2 on the list I got from Paintitblackvette aka Mr.PIB!
TSP 2.5 LS6 heads
224/230 Comp Cam 114 LSA think the lift is 585/591
LS6 Manifold
S2 Ported TB
K&N Intake
Kooks 1 3/4 headers with hi-flo cats and magnaflow
2800 Vig Stall
3.42 gears
Stock Injectors
LS2 Timing Chain
Melling Oil Pump
On a Dynojet she put down 391 uncorrected and 384 corrected. On the same dyno about 1 year ago she put down 340 corrected with just intake, exhaust and tune.
Based on reading other posts, I was expecting more. How can H/C only add 44hp?
One note is during the dyno pull the converted was unlocked - from what I've been reading this can cost ~20 hp???
Car feels strong and with an easy launch registered a 3.8 0-60 on the G-Tech.
I'm not that caught up in dyno #'s as the track yields the true results, but still thinking it's short!
Maybe 384+20 from the converter being unlocked (404) sounds better and adjusted for drivetrain loss (492) better yet, but still think it should have been around 420 based on what these parts did when on Mr. PIB's car - he made 430 on a dynojet.
Thoughts/feedback?
Thanks!
Here you go: http://www.hardcorels1.com/vbulletin...&highlight=prc
Sounds like your old setup ran well, my car is running TSP/PRC 5.3 heads that were bought by the previous owner and it runs pretty good. Would I rather have a different head of course but I will be making one more purchase and 215's aren't big enough
Hopefully will be seeing you at MIR!
Have you ran in some decent weather with the new setup yet?
Anyone have first-hand accounts of the locked vs unlocked converter on the dyno?
Your traps will tell you what kind of power your making. Go make a few passes and see where you are at. Who did your tuning? You can always have Kurtomac tune it.
Car does feel nasty when you stomp on it, like you said...track will tell.
I made only 382 HP on that same Mustang Dyno and went 10.89.
You are right. If people are looking for great dyno numbers, I definitely would not use this one. Too many people loose focus on what the true use of a dyno is and that it is no more than a tuning tool.
ALVETTE00,
Your numbers do seem low to me also. This may be due to the tune.
