Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
"as cast heads"
Old Jul 20, 2009 | 08:17 AM
dadsturn's Avatar
dadsturn
St. Jude Donor '08-'09
Default "as cast heads"
Has anyone other than Vengence racing applied these heads? I am getting ready to pull the trigger on a set and get rid of the old MTI
2e heads. I gained nothing from those heads.
Any performance increases, hp/torq. increases, seat of the pants? I spoke with TF and they stated 40-60hp increase over stock.
Old Jul 20, 2009 | 11:33 AM
LMH4C5's Avatar
LMH4C5
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
Old Jul 20, 2009 | 12:42 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
We had a customer gain 3x rwhp over his LS6 heads. You can't beat these heads for $1679.
Seth
Old Jul 20, 2009 | 02:01 PM
dadsturn's Avatar
dadsturn
Im just really surprised that more builders havent commented on these heads. Vengance stated this morning in an email that they have utilized these heads on around 60 combinations so far and has great results, but other than distributors this is the only "testamonial" to the actual improvements> I would like to hear from someone that has installed these and can give me an owner evaluation.
Old Jul 20, 2009 | 05:58 PM
tail_lights's Avatar
tail_lights
Originally Posted by LMH4C5
Old Jul 20, 2009 | 06:15 PM
happa's Avatar
happa
exactly what heads are these?
Old Jul 20, 2009 | 09:12 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I think Fran at Race Proven Motorsports has installed at least one set of these heads. I could be wrong though.
Happa, They are TrickFlow heads.
Old Jul 20, 2009 | 11:00 PM
tail_lights
Those T/Fs are some mean heads!
Old Jul 21, 2009 | 07:48 AM
dadsturn's Avatar
dadsturn
ttt
anybody??????????????
Old Jul 21, 2009 | 05:25 PM
happa's Avatar
happa
Old Jul 26, 2009 | 07:46 PM
NOT2MELO's Avatar
NOT2MELO
Anyone have any dyno results with a bolt on mod'd car with these Trick Flow "As Cast" heads?
I have seen some results but where on a bigger cubed motor.
Old Jul 28, 2009 | 01:33 PM
HeadGames's Avatar
HeadGames
I just bought a set for my use...I'll post up some pics, gonna throw them on the flow bench too. They look good, but could use some minor clean up to make them great!
Old Jul 29, 2009 | 08:05 AM
NOT2MELO's Avatar
NOT2MELO
Great, looking forward to any updates you can give us on them
Old Jul 29, 2009 | 09:26 AM
UBEASTU's Avatar
UBEASTU
Seth
With these TF's being 220's wouldnt you lose low end TQ / SOTP compared to 205's or possibly 215's on a NA 346 street?
Old Aug 7, 2009 | 09:11 PM
Pewter1's Avatar
Pewter1
Default I Hope To Answer This Question!
I will post my results as I have this going on my 98 Auto by Straightline Performance.........With FLP Headers, Vortex Rammer, Rpm Level IV, Yank SS3200, Stock 315 Rear, DTE Trans Brace, Magnaflow out the Rear.....Baseline Dyno'ed Thurs 325HP/332# Torque. I am going with Vengance Racings TFS "as cast" 220, with a 236/238 595/601 113+2 XRE Lobe comp cam, Non Adj Yella Terras, 25% Underdrive, new oil pump, timing chain, Fast Ported 92MM/Ported LS2 Throttle Body, and Just ordered the Vararam to finish this off and see what can be achieved! I can let everyone know what the real deal is with an LS1 that has never been tuned......only bolt ons.
Old Aug 8, 2009 | 07:54 AM
NOT2MELO's Avatar
NOT2MELO
Thanks Regi, would be nice to see the before and after dyno run and the
different between the As Cast and the CNC machined heads.
Old Aug 8, 2009 | 10:08 AM
Pewter1's Avatar
Pewter1
I wish I did have a set of the CNC TFS heads to compare, but I don't so I will post the results for the as cast,when my car gets done.........
To "as cast heads"
Old Sep 19, 2009 | 09:32 AM
Pewter1's Avatar
Pewter1
425 HP 381# Torque is where we finally came out to with the as cast TF 220's.....ported fast 92mm, and stock throttle body..........going to try a ported one to go with the setup........
Old Sep 19, 2009 | 01:28 PM
NOT2MELO's Avatar
NOT2MELO
Had my car dyno tuned the other day for the first time ever and here
where the results with the Trickflow "As Cast" heads.
Max Power: 435.09 Max Torque: 397.21
Honker Intake
LS1 Maf
LS1 ported TB
Old FAST 78 intake (Self ported)
Trickflow "As Cast" heads cut down to 61cc
Comp 850-16's
FAST 36lbs.
7.5 pushrods
Yella Terra Ultralite's 1.7's
VRX3 226/228 114lsa
Kooks 1 3/4 headers
Kooks Cat'd X-over
Corsa Pace Car Exhuast
3.73 Gears
The LS1 Maf and LS1 TB is hurting me a bit for sure but is a blast to drive so far!
With a FAST 92+, LS2 TB and Z06 Maf should be able to pickup a few hp in the future over the old FAST 78.
Thanks goes out to Ron at Vengeance for all the help and great tech info along with Manny & Rob and also John at Westport!
Old Sep 19, 2009 | 01:57 PM
Pewter1's Avatar
Pewter1
Nice numbers Man fun Ride!
